The water in flow is very slow to non existent. I have checked the hoses into the valves in the machine and there is a water supply there. It is as if the solenoids are not opening the water inlets? Any suggestions will be appreciated.
SOURCE: Fisher&Paykel Smart Drive 601 Both Hot and Cold Water Fill very slowly
Hey there. I've had the same problem recently. It would fill slowly, and then after a while, it wouldn't fill at all. So I got some a new valve. it cost about $NZ30 delivered. You'll need one each for hot and cold. You can get parts from http://www.primedistributors.co.nz/. I think the part you need is 426142. you can check an image of it on the website. Good luck.
SOURCE: gentle annie motor wiring
This according to googled results, and somewhat verified by me:
For the Gentle Annie connect the white/orange/green wires together to from a
star point and the three other ends (red, yellow & blue) go to your 3 phase
rectifier.
You can leave the others hanging. Don't form the star point with the wire
that's green with a yellow stripe, that's the chassis earth. The brown,
purple, and brown with black stripe I think are sensing coils, with a star
point connected to the black wire. 1.4ohm each, whereas the main coils are
4.8ohm and apparently rated for 5A.
SOURCE: Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
SOURCE: Rinse Cycle Doesn't Fill with Water
You may want to double check you have the inlet hoses around the correct way as if you have the cold hose going to the hot valve it would cause this fault. If the machine doesnt spin properly also it could be a faulty Out of balance switch. cheers.
SOURCE: Fisher/Paykel GWL10US washer. Blinking hot and
When they say replace the valve There,s a very good chance the diaphram is the valve is purferated or split (common Problem).But you can Remove the coil from this & with pointy nose plyers you can unscrew the top & inspect the diaphram If it,s ok give us a bit more info Hope this helps.Cheers.
