SOURCE: samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
SOURCE: Samsung LN-T4671F HDMI PC hookup and Audio Problems
you may have to connect it to the audio jack next to the VGA port of PC input as can be seen from this pic
http://review.zdnet.com/sc/32514512-2-300-DT1.gif
The PC input ports are at the top of the pic midway.
I had the same problem before and this fixed it
Hope this helps
Cheers
JigSaw
XoXo
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
SOURCE: PN50A450 Samsung green screen problem
This is a problem in one or more boards in the TV.
If your TV is still under warranty please call Samsung to get if fix at not charge.
parts for your tv are not cheap and labor is not eider.
