Question about Samsung PN50A450 50 in. Plasma HDTV
NEED MOUNTING SCREW SIZE FOR SAMSUNG FLAT SCREEN TV
Posted by mlibby on
CECIL BROWN
    New Friend:
WHAT SIZE SCREWS DOES A SAMSUNG TV LN52A65 REQUIRE FOR THE TABLE TOP MOUNT
Posted on May 26, 2011
What size screws do i need for mounting a vizio 55" to a stand?
This depends on the model being hung on the stand. The size screw to use is usually listed in the manual. Also make sure to check the maximum length of the screw or you can damage the TV.
Dec 03, 2014 | Vizio Televison & Video
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
I have a Samsung B2330HD TV with universal wall mount. The screws with the wall mount do not match the hole size on the tv. It seems as though this is a common problem. Any idea what the screw size I...
I'm told you have to force the M4 screws to fit. This is a computer monitor with a TV Tuner not a TV with a computer input. It was not designed for wall mounting.
Nov 04, 2010 | Samsung Televison & Video
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
Samsung PN50A450 50 in. Plasma HDTV Logo
5,236 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
