Old HTC,
ever heard of the HP forum, (real)
https://h30434.www3.hp.com/
bingo
? ask them, but good luck on relic old HTC.
SOURCE: USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
SOURCE: How do I change the language of my Ipaq HP2210
You CANNOT change the language on an IPAQ. If someone can do it, I would like to know HOW... Good day !
SOURCE: HPiPAQrx5915 wont active sync with pc or laptop by usb or bltooth
What version of ActiveSync are you using? Open ActiveSync on the PC, then open "About ActiveSync" under the "Help" menu - it should be version 4.5. If not, download version 4.5 from Microsoft as a first attempt to fix the problem. If you are using 4.5, try uninstalling/reinstalling again but make sure you do a soft reset (push the pin on the top of the device) before you connect the Ipaq. If this doesn't work let me know and we'll try some other things.
