If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Do you have these lines on the screen, while taking pictures in the dark, or ale these lines there always, While taking pictures and viewing the pictures as well? Dod you view the pictures on the computer and are there also lines or not on the PC?
Possible screen controls in the set are up too high---if you turn picture and brightness to zero does the screen get full black?
screens set too high would give diagonal faint trace lines in the picture.
These sets also should get a annual cleaning of the lens and sometimes the mirror inside= if this is the case the picture will usually look darker and dull ----this will not affect lines in picture.
the lens are easy to clean but other actions depend on what your response is to the above information.
CCD going BAD call Samsung they will do it FREE of charge as it is a known problem after some time the pics will be total BLACK and BLANK pls call them and ask them about BAD CCD
You have a number of bad capacitors in the vertical circuit. If you can solder, you should be able to repair this yourself. I'll look up your model to get the parts needed.
Dan
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
I am not able to see the picture clearly.
(FinepixA210)
I can see horizontal lines on the picture.
