Question about Canon PowerShot A430 Digital Camera
Horizontal line pictures
I am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
Handojo
Posted by kgading2000 on
  • malkavian_pr
    malkavian_pr Mar 27, 2013
    yea mine the same :D
Anonymous
Am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
Posted on Aug 09, 2009
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Purple images with horizontal white lines
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Nov 14, 2008 | Canon PowerShot S60 Digital Camera
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
White Lines and blurry Pictures
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Mar 23, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Picture taken is so bright and with trasparent horizontal line
more detail casio ex-s600 overexpourse
Feb 24, 2008 | Casio Exilim EX-S600 Digital Camera
Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
It appears this problem is due a failing CCD device in many brand cameras. All the manufactures use the same source(s). I have not persued Casio as yet, but other companies are offering a recall to replace the CCD for free. I plan to use this approach with Casio. Search the web for "failing CCD in digital camera", it describes exactly what we are observing.
Dec 02, 2007 | Casio EXILIM Card EX-S770 Digital Camera
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
This is a CCD failure. Go to the Casio Tech support team. There has been an issue with a batch of CCD's and a recall on certain models of all makes This may be one of them
Jul 16, 2007 | Casio Exilim EX-S500 Digital Camera
Canon PowerShot A430 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
