Televison & Video Logo
Posted on May 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
Toshiba sd-kt50 turn on open/close says hello protection comes on and goodbye shuts it self off. We had two one second power offs but wasn't associated with a storm
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 255 Answers
  • Posted on May 08, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
255
Questions
0
Helped
77960
Points
638
The sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (http://www.geocities.com/its_yahell/toshiba_sd220e.html)
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
3answers
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
1helpful
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Hello, I have had my Home Theate packed for a few years now. I have 2 Toshiba remotes. Neither of them operate the system. One is an SE-R0094 and the other remote is an NB001. I tried new batteries in...
The SE-R0094 is the original remote for the SD-KT50. So should work with it unless it's faulty.
You can get the service manual for the SD-KT50, that might give you clues as to why it doesn't work. It's free the manual, just type the model number into Google.
1helpful
What is the region code for toshiba SD-K750 DVD player
hello,
Pressing the Open button on your remote control to open the drive tray, Press the 2403960 button on your remote control
Press the Enter button on your remote control to change the region to 1 for
region 1, 2 for region 2, and so on, or 9 for multi-region playback, Press the Open button on your remote control to close the drive tray, Power off the DVD player, Power on the DVD player
Report this hack (requests/questions/spam/wrong/****).-->
The Open/close does not work. Power is on and it
First try resetting the player. Unplug for 1/2 hour-1hr., press and hold power button for 3 seconds, wait 1/2 hour, plug back in and it should work. Otherwise you can pry open the door with a paper clip. Slowly pull door as far back as it will go, then press eject button and see if everything aligns itself back on track.
1helpful
Toshiba SD-K760 region codes.
I found this on another site, worked for me, hope it helps...
icon_minipost.gifRegion code hack posted by Stratos, April 30 2006:
1. Press the Open button on your remote control to open the drive tray
2. Press the 2403960 button on your remote control
3. Press the 1 button on your remote control to change the region to 1, 2 for region 2, and so on, or 9 for multi-region playback. New region number will appear on screen.
4. Press the Open button on your remote control to close the drive tray
5. Power off the DVD player
6. Power on the DVD player
5helpful
2answers
Region code
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
2answers
Sd 43ht toshiba
In most cases "PROTECTION" message appears when something is improperly connected to system. Try to disconnect everything, and reconnect it step by step.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
