The power supply adapter may be dead, should be tested, if okay! remove the main battery will load player down in some cases. If still no result! cheaper to replace than repair.
Hi bbabitsky, If you have necessary tools and test instruments,
know safety precaution in basic troubleshooting try the steps below to solve
your problem. Assuming that the disc is good. 1.Clean the lens.-
Sometimes because of dust the lens can't read any disc. Try clean the lens by
soft cotton buds. Be careful while doing this. 2.Replace the ribbon- Check
the ribbon connected to the lens from the main board forscratch,
damage. Once it has an open line then of course the lens can't read the
disc. Also try to erase the contact by pencil eraser. If you've done the steps
above and the symptoms still there then the next step requires you a little
knowledge in soldering technique and reading the ohmmeter. 3.Check the motor- Check
the motor that spin the disc with an ohmmeter. You can test it using the
ohmmeter (x1) even it is connected on the lens assembly.Good motor- reading
should be fairly high and it will spin.Bad
motor- reading will drop to low resistance and will not spin. I've suspect that you're unit has a defective spindle motor. You may visit this link http://www.fixya.com/support/r7833671-change_defective_motor_portable_dvd for more info. Hint :50% of my
repaired unit the above parts are commonly caused of the problem. If you confirmed that you have a defective motor
then replace it with a new one. Before replacing the new motor you have to
check the clearance of the disc holder with the old one. The clearance should
be the same as the old because if not the lens will not read the disc if it is
too far or too close.
Ifyou already cleaned the lens, and confirmed
that the ribbon is good as well as the motor then I would advice you to send it
to repair shop because the next step should be done with anexpertbecause it is quite
technical diagnosing the fault between the pick-up lens and the main board. Hope I helped you. Have a nice day! Thanks for usingFixya.
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high. Now certain cleaner disks are not read and so will not be tracked. The best is to clean manually the laser head eye with a cotton bud very softly and without any pressing of the lens eye. If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer. But if any of the above seems otherwise we must recheck with possibilities of the processor board. check the power to the mP sections but the signal tracking of the D/A conversion stages might need an oscilloscope or a higher degree of probing.
I understand that your DVD player is playing at times and then plays or skips or jerks. It may beccome worse when the DVD playings a little longer as the heads move out. First you must use a good swab/ and earr bud should be good, to dry polish off the optical lens head- the eye inside the tray. If you get some better performance then wee can be confirmed that your optical heads need a replacement. You will have to open the set find the actual par number and replace with the method required. If not get a help to do this, the new head must be desoldered off the static safety solder bridge, and installed. Hope I could help. Good day
This is a known issue with this TV. The following might resolve it:
Check Mute and Volume:
Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume.
Inspect External Speakers:
If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues.
Test Different Inputs:
Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box.
HDMI Troubleshooting:
If the issue persists with the DVD player over HDMI, consider the following:
HDMI Cable: Check the HDMI cable for damage or loose connections.
Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary.
Mainboard Replacement (if needed):
If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard.
TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
Serial numbers don't work Judy
https://www.google.com/search?q=A10A13799C3300
They are purely a numerical identifier of when it was made, year, day, number on the shift, whether it Joe or Billy who did final inspection.
With a MODEL number I can find them easily with just 'make model manual'.
Toshiba
http://www.toshiba.com > support > content
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please.
62 pages
Toshiba
PDF
Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please ...
62 pages
No you can't the Insignia remote is for that model television only. Companies don't make their remotes so they operate other makes of televisions. Buy a Copy Remote for the Toshiba
https://www.google.com/search?q=insignia+remote+NS-RC03A-13
