20 Most Recent Goodmans DVD2100B DVD Player Questions & Answers
0answers
Ghdd177dvdr
Be the first to answer 12/9/2017 4:24:03 AM • Goodmans... • Posted on Dec 09, 2017Be the first to answer
Goodmans DVD Recorder/Freeview Problem
My Goodman's built-in dvd has just gone green and purple on the TV screen,TV is ok but dvd is now just showing the 2 colors,what can I do,
7/20/2017 9:51:38 AM • Goodmans... • Answered on Jul 20, 2017
0answers
Conictin withe pc
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
1/16/2011 4:54:26 PM • Goodmans... • Answered on Jan 16, 2011
My machine keeps coming up with a no disc message
the reason is doing this is because the pick up sensor is bad (laser) u can try to put a disk cleaner , if this dont work the laser need to be replace
1/4/2011 4:20:57 PM • Goodmans... • Answered on Jan 04, 2011
No disc
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
3/10/2009 7:40:34 AM • Goodmans... • Answered on Mar 10, 2009
Even with new batteries, remote does not work
Store manager suggested purchasing a new remote at $70. I requested asking the manufacturer for repair. Feedback, repair more costly than new remote. I opted for buying a new DVD player, not goodmans, for $100. Thanks.
1/25/2009 9:45:32 AM • Goodmans... • Answered on Jan 25, 2009
I purchased a goodmans tele,stand
i need a code to record the dvd what is it
11/9/2008 9:08:09 AM • Goodmans... • Answered on Nov 09, 2008
2answers
Region code
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
7/6/2008 8:31:28 AM • Goodmans... • Answered on Jul 06, 2008
Goodmans dvd recorder noise
Hey cylconesid, I have answered on the other thread, but in short yes. It could also indicate that they are both protecting your circuitboard from burning out due to another problem, possibly a dying motor. The best case senario is that the capacitor was faulty, and the little vibrating thing (thermal fuse)was about to blow as the next level of protection.
2/5/2008 12:01:38 AM • Goodmans... • Answered on Feb 05, 2008
Goodmans dvd recorder not working
Hey there cyclonesid, capacitors look like little batteries, and have a shiny flat top with perforation lines on it. If the capacitor is going or gone, this flat top begins to peak and sometimes show points of corrosion. jpe is associated with thermal fuses which are used to protect devices from excessive ambient temperatures. These are not expensive and relatively easy to replace (if required) by a professional. I hope this helps. Good Luck!
2/4/2008 11:36:34 PM • Goodmans... • Answered on Feb 04, 2008
Goodmans dvd2200
I'm sorry for your inconvenience friend, but there are no specifics on how to change the Region Code on a manufactured DVD player since the coding is part of the hardware. You can try buying Free region DVD's witch are little rare or try a new DVD player, Try selling your dvd player to some body in the UK trough eBay.
11/14/2007 6:03:20 PM • Goodmans... • Answered on Nov 14, 2007
My Goodmans television has refused to come on but the standby light is on.
Did you try pushing the On button of the set? New batteries for the remote? Power Reset, unplug from the wall socket, press and hold the power button for one minute, plug it back in?
8/26/2023 7:15:26 PM • Goodmans... • Answered on Aug 26, 2023
My goodmans 46 plasma LCD TV goes off every five minutes and then on again after one minute BY ITSELF continuously
Time for a new TV, in most cases plasma sets aren't worth fixing, parts are hard to find an costly plus one issue can lead to another, not something most people can fix without electronic experience
1/2/2022 12:17:23 AM • Goodmans... • Answered on Jan 02, 2022
I need a code for goodmans soundbar GDSB04BT50X remote control. Thanks.
The applicable code(s) would be found in a compatible remote control.
12/4/2020 5:49:25 PM • Goodmans... • Answered on Dec 04, 2020
My goodmans Ld2661 tv has child lock on and I don’t have a remote control can I turn it off using the controls on the tv?
No idea if any of the suggestions below will work. https://quuq.org/forum/index.php?topic=3408.0 https://www.avforums.com/threads/goodmans-ld1510-on-child-lock.812276/ Several postings on the internet found using https://www.google.com did not suggest a certain answer. Please use Comment menu to update your question if you find a way that works for you, or you want to report back on what you have tried already.
11/1/2019 8:52:28 PM • Goodmans... • Answered on Nov 01, 2019
2answers
Goodmans tv needs tuning
What is the exact model number to your TV?
5/28/2019 11:38:30 AM • Goodmans... • Answered on May 28, 2019
Goodmans DVD2100B DVD Player Logo
22 questions posted
Top Goodmans Televison & Video Experts
W.L.
Steven Wander
Steven Wander
Colin Stickland
Colin Stickland
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Goodmans Televison & Video
Most Popular Question
no disc
  • Televison & Video
