Toshiba 1360 Black and White Copier Logo
Posted on May 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WRENCH IS DISPLAYED. WHEN I HIT C/ KEY AND #8,
WRENCH IS DISPLAYED. WHEN I HIT C/ KEY AND #8, C7 IS DISPLAYED
Anonymous
Level 3:
  • Master 371 Answers
  • Posted on May 06, 2009
Anonymous
Master
Level 3:
Answers
371
Questions
0
Helped
147764
Points
1106
You have a bad fuser.
I forget my lock to mobile nokia c7 and imel : 35375541950660 i fond to master key
Go to this page((((http://www.keyables.com/2012/05/reset-nokia-security-code-with-nss-pro.html)))))) 100% working link
i have the same problem and now resolved
I need unlock code for nokia c7 movistar spain locked
u can get the unlock code for your nokia c7 model from by using this link http://www.theunlockarena.com/
following instructions makes u easy to unlock your mobile
1 - Switch on your Nokia C7 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C7.
3 - Compose #pw+CODE+1#.
4 - The Nokia C7 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C7 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C7
Each Nokia C7 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C7 mobile phone using the form above.
1helpful
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
I need to change the chuck assembly. i have removed the screw from the center,but i am not able to remove the chuck. any suggestions on removing it without damaging the drill will be greatly appreciated.
Get a large 90-degree allen wrench. It's best to use the largest allen key the drill can accommodate, at least 3/8" to 1/2". Put the short end of the allen key in the chuck and, with the long end of the allen key pointing straight up, completely tighten the chuck.
Firmly holding the drill on the edge of a table, you're going to have to hit that allen wrench with a hammer, hard. Use the flat side of a hammer to hit the allen wrench so that the blow will spin the chuck counter-clockwise. Sometimes it can take a real hard swing, so swinging through smoothly helps.
3helpful
3answers
I have a toshiba 1370 copier....the repair wrench is flashing and won't let me continue, how do i get the wrench to stop blinking?
switch on the machine, holding down 0 & 8 buttons, type in 89, press the green button, enter a 0, press green button again to accept the new value. switch off & then just switch back on as normal.
good luck.
1helpful
I HAVE THE WRENCH ERROR; DO NOT KNOW WHAT TO DO FROM HERE
If you push clear and 8 does it say C7? Push 0 and 8 as you turn on the copier it should say ad on the display push 89 and start and (I bet 3 is displayed) push 0 and start this resets the "c7 counter"
1helpful
Wrench light on and c7 code appear
C7 is a Fuser Error......The hot part where the paper passes through before exiting the machine is known as the Fuser or Fixing unit etc.
There are 3 parts involved and any of which when they fail will give a C7 error code. The Heating Lamp,Thermisor or Thermal Fuse.
This is a live area of the machine so you wouldnt be advised to attempt a repair without at least a restricted electrical license.
More than likely one of the parts mentioned will need to be replaced and then the C7 error count reset through "08"
6helpful
2answers
Toshiba 1360 copier
Turn it on holding down 0 and 8. Key in 89, press start. press 0, press start. Turn it off and on.
C7 error???
Turn on the power holding 0&8, key in 89, and press print. A 3 will probably be displayed. Key in 0 and press start. Recycle power.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
