The problem is that when i start my computer 10-15 it is working fine
but after sometime i cant increase or decrease my volume it coming that
(There are no active mixer devices available.to install mixer devices ,go to
control panel ,click printers and other hardware ,and then click add hardware)
but after i restart my computer it is working fine for 10-15 min
it is a motherboard CD problem i don't know
The Problem> Sound: Placing the mouse pointer over the ICON to the lower right of your screen should indicate the percentage of Volume your speakers are adjusted for. Right click and you get the Open Volume Mixer section. The playback devices can be your computer speakers or a separate headset with microphone. Here you can make adjustments accordingly. At the bottom are Volume Control Options that allow you to increase or decrease the audio reception. Generally, when you insert an external Headphone with Microphone into the sound port in; an automatic disconnect may occur preventing computer speakers from working. This is common with Laptops. If you lack sound, you may need to update the sound drivers, change cables, and/or check to see if the speakers work on another device.
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
