the microphone of the handset doesn't work so anyone using it cannot speak to callers but can hear them. the phone does work if connected to a headset.the microphone of the handset doesn't work so anyone using it cannot speak to callers but can hear them. the phone does work if connected to a headset.
First de-register by pushing # and end simuntaneously. Select de-register. Then place on the base until it says that it has registered. Uniden Registering
We just had the same problem with our AT&T 2462 hand sets. They simultaneously stopped transmitting, and though we could hear the caller, no one could hear us on the other end of the line. We unplugged the base from the power source, took the batteries out of the hand sets, waited 20 seconds, then plugged everything back in and they worked just fine. Hope this helps.
If phone is more than 1 yr. old, battery needs to be replaced, if not reset base by disconnecting power, pressing and holding delete key while reconnecting power.
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
How did you test it?
