Cyberhome DVR 1600 DVD Recorder Logo
J
Joan Posted on Oct 26, 2013
My player does not always turn on. I try the remote and push the button. Nothing! I unplug and replug Nothing! And then sometimes it will turn on! Any suggestions?
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney ([email protected])
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
5helpful
3answers
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
1helpful
DVD player will not open
try unplugging it for about 2 minutes to clear some memory and try it again. the tray motor may be shot or skipped a tooth on the gear and not hitting the switch. you may need to take the cover off and physically do it.
2answers
Rca rt2870 wont turn on
a fuse may need to be replaced
1helpful
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
2answers
Unit won't turn on.
Is tape(s) in the unit? Are they "shuttling" when you try to power up?...accordianman
10helpful
2answers
Panasonic dmr-e50 remote control
The aswer is in the manual that can be had on line, page 45. You have 3 different remote types, 1,2,3, All you have to do is hold down the ENTER button and the number 1 or 2 or 3 on the remote for a few seconds and it will change the setting.
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
