20 Most Recent Toshiba SD-K860 DVD Player Questions & Answers
try unplugging it for about 2 minutes to clear some memory and try it again. the tray motor may be shot or skipped a tooth on the gear and not hitting the switch. you may need to take the cover off and physically do it.
Toshiba SD-K860... | Answered on Dec 14, 2009
Sound like the disc is stopping inside the player this can happen when you push the tray into the player instead of using the eject/insert button. This can cause the tray to slip its guide plug on the rack and pinion tray release this will also cause tray blocked unknown disc errors, this will need to re-seated.
It is also caused by excess dust and finger grease inside of the player that can build up over a number of years I suggest that you first unplug and then remove the lid from the device give the plastic internals a clean with rubbing alcohol.
DONT TOUCH the record/play head or power up with the lid off.
Toshiba SD-K860... | Answered on Nov 29, 2009
Try cleaning the lens with a Disk cleaner, if this doesnt work the lens or motor could be faulty.
jon
Toshiba SD-K860... | Answered on Aug 23, 2009
Usually you cannot buy replacement powersupply boards for dvd players unless you buy a scrapper one off an auction site and use that , but before you go out spending any money, check the capacitors on the board which look like little blue cans, see if they have a buldge in the top and if they have then they will need changing. Check for any burnt components too.
jon
Toshiba SD-K860... | Answered on Aug 07, 2009
on the remote, press "progessive" until you get a signal through hdmi to your tv
Toshiba SD-K860... | Answered on Jul 06, 2009
chuck in bin,they are a throw away item,not worth stuffing round with them.
Toshiba SD-K860... | Answered on May 01, 2009
could be just the mechanism that detects whether theres a disc in.
Have to open it up to find out tho, not a good idea unless you know what youre doing.
Toshiba SD-K860... | Answered on Mar 28, 2009
well, I unplugged it overnight, and it's now working.
Toshiba SD-K860... | Answered on Feb 24, 2009
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Toshiba SD-K860... | Answered on Feb 10, 2009
https://www.google.com/search?sxsrf=ACYBGNTVGZctZ8KkQV0t4ebQ3lNunwx-UQ%3A1581955911674&source=hp&ei=R7tKXqvkJobqav-tkkg&q=Unlock+pin+on+toshiba+22D1333B&oq=Unlock+pin+on+toshiba+22D1333B&gs_l=psy-ab.3...74105.74105..75007...3.0..0.290.290.2-1......0....2j1..gws-wiz.....10..35i362i39.PylHZy-v9vE&ved=0ahUKEwjro6eB_djnAhUGtRoKHf-WBAkQ4dUDCAU&uact=5#kpvalbx=_UsVKXvWjEcySlwTTm6HgCA29
  1. Using the remote control, press the following button sequence in a timely fashion: 1 , 2, 3, 4 (This will release the "Retail Lock" mode)
  2. Enter the User Menu and locate Reset Factory Defaults for the subject model.
  3. Complete the Factory Defaults reset.
  4. Power on the TV.
You can reset and eliminate the lock on some televisions without the remote, using a few tactics. Hold the power button for five seconds. The television will automatically restart. If the lock is still on, unplug the television and remove the battery from the back panel of the television.
Toshiba... | Answered 2 days ago
Save your money by having your TV repaired by professional technicians.
Toshiba... | Answered on Feb 14, 2020
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Toshiba... | Answered on Feb 12, 2020
Toshiba SD-K860 DVD Player Logo
19 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
dvd player will not open
  • Televison & Video
