Pride Value Line Revo Scooter 3 Wheel Logo
Andre Lauzier Posted on Sep 25, 2013
I lost the key and a locksmith told me that he couldnt make anoyther one. Is there a way to order a new one?
Dean Rouse
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 26, 2013
Dean Rouse
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
2716
Points
14
Any Pride Mobility dealer or repair centre can supply keys for your scooter, but probably won't be cheap. Have a search for Healthcare Distribution Direct and send them an email.
2014 Scion TC won't start after locksmith attempted to cut new keys
limited info generic answer assuming keys are lost and had key cut using vin locksmiths can cut keys but need one that is auto authorized so it can be programmed --dealer is option if none of locksmiths are able to program the key
CAN I put the new transponder key i gotcut at honda in RKE TRANSMITTER OUTLET TO PROGRAM it?
everything will more than likely need to be reprogrammed at the same time. contact a local locksmith that does automotive work. lock smiths are much cheaper and do just as good a job.
I need a replacement key for the motor compartment for a 1987 Champion La Salle. Any help is appreciated.
If you have lost your key, you have two options. You can call a locksmith and have a new key cut for the lock, or you can order a new lock with a new key and then call a locksmith to open the lock to access the compartment and install the new lock.
2answers
WHERE CAN I GET A KEY FOR MY 2015 YAMAHA ZUMA
I took out the whole ignition from my zuma 125 and took it the a locksmith. They made me a new set of keys for less than $50. Or you can order a new ignition thru Yamaha with the key set. That may cheaper than the locksmith.
Lost all keys to 2001 Toyota Avalon. Dealer says I must buy a new computer in order to have new keys set for this vehicle. Is there any other cheaper solution?
the best thing i can suggest is find a locksmith who specializes in making car keys. something similar happened to my brother and my friend. my friend lost his keys, to an older acura, the locksmith, he got a code off of the glove compartment, and cut the key based on that code. my brother, has a 2001 audi a4(similar key system), he broke his key, he went to the dealer and they were charging him 400 dollars for a new key. so he got an uncut key from ebay for 15 dollars, took it to the same locksmith, cut the key based on the broken one, and only charged him 20 dollars. 35 compared to 400, huge difference. i know its different situations but i think a good locksmith will be able to make the key for you without charging you all that extra stuff. if you live in the cerritos, california area, i can tell you the exact location of the lock smith. if not, i will gladly help you in your search for one, or any other assitance you may need. i put a link to an ebay key that should be for your car, uncut of course. i hope this helps, and goodluck.
http://cgi.ebay.com/ebaymotors/NEW-UNCUT-TOYOTA-IMMOBILIZER-TRANSPONDER-CHIP-KEY-4C-_W0QQcmdZViewItemQQfitsZYearQ3a2001Q7cMakeQ3aToyotaQ7cModelQ3aAvalonQQhashZitem53e7b6c4b9QQitemZ360369800377QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
2answers
Lost my car keys "what are my options"
You should be able to contact the dealer and give them your VIN with proof that you own the car and they should be able to make a key from the VIN. Other way is to contact a locksmith and have them come to your house and make a key for you onsite. Not cheap but quite effective.
1997 Nissan Pathfinder LE - Lost Keys - Key Code?
HI any nissan dealer should be able to get key codes for you just give them the vin number they normally charge for this but not to much ,they wil usually ask for some id and proof it's your car steve
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
