20 Most Recent Pride Jazzy 614 Hd JAZZY 614HD Questions & Answers
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Pride Jazzy 614... | Answered on Jul 21, 2019
Batteries are done.
Pride Jazzy 614... | Answered on Sep 03, 2017
Is the controller locked? Does the controller beep? The best way to troubleshoot the problem is to go up on Jazzy's website and download the service manual
Pride Jazzy 614... | Answered on Oct 08, 2016
Fuse? Did your Jazzy get wet?
Pride Jazzy 614... | Answered on Aug 02, 2016
check your battery connections they are giving a code that something there maybe wrong. For instance cable slipped off or the battery connections. The connections may have been installed wrong, especially if this happen directly after someone changed the batteries. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Pride Jazzy 614... | Answered on May 03, 2016
The Joystick gimbal has dirt or grim in it, need new joystick.
Pride Jazzy 614... | Answered on Apr 09, 2016
hi T. Phelps, sounds like the coupler situated between the motor and gearbox is broken etc.
Regards
Rob
Pride Jazzy 614... | Answered on Feb 08, 2016
Hi Timothy , okay firs t look at the brushes ,,, make sure the brakes are releasing fully ( loud click) and finally check the connections to the joystick..._ .
Most likely the brushes ..maybe they are sticking ?
Regards
Rob
Please rate my response..
Pride Jazzy 614... | Answered on Nov 10, 2015
hi, the brake on top of the motor on the left hand side ...
Regards
Rob
www.gewizrepairs.co.uk
Pride Jazzy 614... | Answered on Nov 03, 2015
hi Robert, normally this is because of the motor on the left hand side either needs new brushes or the brake is not freeing 100% , at worse it is a joystick fault ... check the joystick connections.. and the connections to the left hand side motor
Regards
Rob
Pride Jazzy 614... | Answered on Oct 30, 2015
Hi if the batteries r 5 years old it would be a good idea to replace them ...u can't rely on you're charging circuit giving u a true reading on the condition of you're batteries they have to b tested with a BATTERY LOAD TESTER they put a 100 amp load on them this will give u a true reading on the condition of you're batteries ..cheers
Pride Jazzy 614... | Answered on Sep 11, 2015
hi, that is the code for a brake fault , check the wiring to the brakes located on top of the motors...
Regards
Rob
Pride Jazzy 614... | Answered on Jul 10, 2015
sorry but i can't see how's that a fault, can you please explain in more detail ?
Regards
Pride Jazzy 614... | Answered on Mar 23, 2015
Each motor has a brake system attached to them. One of them isn't working and is sending a fault signal to the controller. It needs to be serviced.
Pride Jazzy 614... | Answered on Feb 24, 2015
You can get the service manual from Pride's website. It will tell you what the flashes mean and how to fix it.
The 3rd wore of the charger plug tells the controller to shut off all power to the scooter while the charger is on. Check the plug for a broken wire
Go to Pride's website to download the service manual. It has more information than the owner's manual does.
possibly have someone fix the ramp so itis shorter might be easier and quicker .
Pride Jazzy 614... | Answered on Jan 21, 2015
hi, where are you please ? ... there can be number of reasons for this, the most common...
1. the reverse logic of the controller is breaking down..
2. the joystick mech ...
Regards
Rob
Pride Jazzy 614... | Answered on Jan 10, 2015
Copy/Paste your question in search bar on YouTube,I hope this helped you.Colin
Pride Jazzy 614... | Answered on Nov 23, 2014
Pride Jazzy 614 Hd JAZZY 614HD Logo
65 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
jazzy 614 hd motor runs but wheel not
  • Health & Beauty
