20 Most Recent Pride New Mobility Legend 4 Wheel Scooter Questions & Answers
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Pride New... • Answered on Oct 01, 2020
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Pride New... • Answered on Sep 04, 2018
Call the manufacturer. I found the chinese versions not all that great because of the language barrier when translating them for print. ALWAYS check ebay first you may be lucky there.
Pride New... • Answered on Feb 10, 2017
Try under your feet! Remove the rubber mat - treat the rubber lugs carefully as they can be damaged and very difficult to replace. Remove the hatch, and under it you may well find the fuse box. Treat with great care, do not short the batteries or give yourself a nasty electric shock.
Pride New... • Answered on Aug 02, 2016
Possibly your charger or batteries or main 10 Amp fuse Pride may tell you (as they told me) that it doesn't have one, nevertheless I found mine below the floor hatch under the foot mat ... and? It was blown. It's a standard 10 Amp car fuse, it cost a few cents and the problem was fixed. The provider had said that it was definately my batteries and that he would replace them at €157.00 He didn't seem interested when I told him that they were already new! " One of them will be faulty then" he said. Find that fuse, it's not in the tiller fuse box - but please don't forget that there is a risk of a power short or a bad electric shock be very careful and/ or get an electrician's help.
Is the charger faulty? It happens
There could well be, Pride hides them there and denies they exist, but they do.
Pride New... • Answered on Jun 02, 2016
Almost all scooter manuals can be downloaded on the internet, do a Google search.
This is very likely to be a binding hand brake, with a bit of help you can check this. IT IS NOT DIFFICULT BUT IF YOU DOUBT YOUR ABILITY GET A QUALIFIED MECHANIC TO DO THE FOLLOWING; First loosen the rear right centre wheel nut ONLY and then carefully raise the back wheels off the ground and place blocks securely under the chassis frame. Continue undoing the central wheel nut (only) and remove the rear right wheel and small axel key. With the scooter securely raised and all hands, clothing and obstructions out of harm's way switch on the scooter and use the wigwag to run the motor. With luck the noise will have gone, in which case it very probably was a binding brake pad, possibly caused by a dry, sticky cable or rusty or dry parts. Try a spot of cable/ leaver lubrication (WD40), do NOT get grease or oil on the brake pads or on the wheel drum, clean these with a dry brush and rags. After lubrication work the hand brake leaver until it feels free and the lever returns fully. Reassemble the right rear wheel onto the stub axel matching the groves exactly then tap the key back into the matching slot. Test while the wheel is still off the ground, with luck the noise (which may also sound like cyclical scraping) will have gone. NOTE! If you have any doubt about your ability to do this safely, have your brakes serviced - any good car or motorcycle mechanic would be able to thoroughly do this in about 30 minutes.
your throttle pot needs replacing. your thumb lever attaches to the throttle pot.
Pride New... • Answered on Feb 18, 2016
mechanical error.. did u buy it new?
Pride New... • Answered on Dec 08, 2015
hi , that is a throttle pot error, check the pot itself to make sure it's not come loose and check the connected wiring ... Regards Rob www.gewizrepairs.co.uk
Pride New... • Answered on Jul 13, 2015
and the question is ? Regards Rob www.gewizrepairs.co.uk
hi, Okay now have you removed the motor from the gearbox, if so did you refit the coupler that located between the motor and gearbox, another cause is a sized brake... I can help in all cases , UK based ? Regards Rob www.gewizrepairs.co.uk
Pride New... • Answered on Jul 10, 2015
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
Pride New... • Answered on Feb 24, 2015
The legend has a Curtis controller. The flash codes you provided points the problem to a faulty throttle pot. If a new throttle does not fix the issue, then your problem is the controller itself.
Pride New... • Answered on Nov 25, 2014
You can learn how to adjust the seat on the link below. Page 18
http://www.rascalscooters.com/manuals/300_manual.pdf
Good Luck
Pride New... • Answered on Nov 18, 2014
Possible blown bulb. If yours is like mine then you can remove the lens in front to access the bulb. If the unit is still under warranty do not touch it. Contact the place you purchased it and have them replace it. There may be a reason that the bulb blew out that a simple bulb cannot correct.
Pride New... • Answered on Apr 18, 2014
Pride New Mobility Legend 4 Wheel Scooter Logo
116 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike
Dan Webster
Dan Webster
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
motor spinning but drive not engaging
  • Health & Beauty
