Hi there my car Starts when cold but doesn't start when hot (after 5 min)? audi B4(A80) 2000CC 1992
SOURCE: Audi 80e 1991 hard starting when cold
I've owned the same car. Check that the fuel relay 'primes' the system before you start the car. When you turn the key to the on position (all you dash lights, ready to start) you should hear the fuel pump run for a second or two. If it doesn't run you can replace the relay for about $30. If the relay is not the problem, it may be a check valve within the fuel line to the engine. This valve keeps fuel from draining back to the tank when the car is sitting. That way, there is fuel close to the motor when it's time to start. The temp senor was not a bad shot, they were thinking it was bad sensor not telling the cold start injector to run. Obviously not the case. However, the injector itself may be faulty in some way. As long as the car always starts, it's one of these problems, assuming the ignition system and engine mechanicals are in running order. good luck. JK
SOURCE: problems with my 1995 Audi A6 QUATTRO
replace the coil pack, sounds like it is over heating.
SOURCE: 1990 Buick Century 3.3L Check Engine Light comes on, stalls.
Need to check for fault codes. Possibly a faulty sensor causing the fuel system to run rich or lean.
SOURCE: VW Jetta starts, then turns off immediately
try checking the throttle position sensor or the idle control valve both can keep it from running.
SOURCE: rangerover 3.0 td6 2003 poor starting when hot
secondary fuel pump under ns nr tank will cause poor hot start if pressure delivery is low.
