Question about Metra Car Audio & Video
Im using a metra cf-ajlo line out converter , what does the brown wire on the outputside go to ?
Posted by Jason Macaulay on
Ignacio Ibanez
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
It’s a ground, if your amp still won’t turn on after u finished installing Then use brown one as a ground and ground it to the same one as your amplifier.
Posted on Jan 21, 2019
1 Related Answer
Rob C
  • 547 Answers
SOURCE: Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
Posted on Oct 02, 2009
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1995 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1995
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fuse Panel
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWM: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
It was wired for a 4 wire flat trailer plug. the plug was ripped off and now there are wires coming from both tail lights and the drive lights on rear passenger and trailer dont work. Green, Black, brown/w...
You need to install a 3-2 wire converter. I suggest a CURT 56175 then
1.Using a test lamp, identify the corresponding wires in the harness for the left turn, right turn, tail lights and brake lights. 3. Temporarily remove the vehicle's negative battery cable from the battery. 4. Using wire taps, attach the input wires of the tail light converter to the corresponding vehicle harness wires identified in step 2 as indicated.
Converter Brown Wire: Tail Light Circuit Converter Yellow Wire: Left Turn Circuit Converter Red Wire: Brake Light Circuit Converter Green Wire: Right Turn Circuit
5. Locate a suitable mounting location for the ground eyelet on the vehicle near the converter on vehicle's frame or cross member.
And your ready to tow!
Mar 08, 2011 | 1999 Plymouth Grand Voyager
Installing CD player
here is the wiring schematic.
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Window Trim Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 4" x 6" Side Pillar Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
And you will need a Wire harness... Metra #GMRC-LAN-01
And a mounting Kit Metra #99-3305
And antenna adapter Metra #40-cr10
This is for the basic radio... if you have upgrade NAV/Onstar/Premium sound.... there are different wiring harnesses available.
Let me know if you need more help.
Jan 08, 2009 | 2004 Chevrolet Silverado 2500HD
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1994 Honda Civic This...
1994
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
on Apr 01, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1993 Honda Civic This...
1993
Constant 12V+: White/Blue
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Orange/White
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic This...
1992
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1988 - 1991 Honda Civic...
1988
1989
1990
1991
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Accessory: Blue/White - Ignition Switch Harness
Trunk Pin: Green/Black - (-) Harness from Dash Indicator
Parking Lights: Red/Black - (+) Fuse Panel
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Red - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, 13-pin connector.
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
1984
1985
1986
1987
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
1984, 1985:70-1388
1986, 1987:70-1720
Tach: Blue - Coil
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1983 Honda Civic This...
1983
Illumination: n/a
Dimmer: n/a
Front Speakers: 5 1/4" Side Panels
Left Front (+) Blue
Rear Speakers 6 1/2" Rear Doors
Left Rear (-) Gray/Black
NOTES: - none -
Metra Brand Wiring Harness: 70-1388
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
1980
1981
1982
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Car Audio & Video Logo
1,002 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
