SOURCE: Panasonic Lumix DMC-F7 - Help!
there are 2 menus - a simple one ( has a red heart ) and the one with the language option : ( in japanese mode , all items are in - duh - japanese ) so press the menu ( center ) button until the last selection . . . the last item is language ;
SOURCE: Camera in japanese language i want in english LUMIX DMC TZ5
Select menu
Select spanner(wrench) for setup menu.
Scroll down through the menu, there are five pages of menu items on my camera! it moves to a new page when you move off the bottom.
The language option is the penultimate item - it has an icon of a head with a speech bubble.
SOURCE: change language from englich to chinese for DMC
Go into the setup section of the camera menu. You will find language options.
SOURCE: how do you change the language settings on a
Language should be the second-to-last item on the Setup menu.
SOURCE: language change from japanese to english
Slide the [REC]/[PLAYBACK] switch to the REC position (camera icon). Set the mode dial to AUTO (green camera). Press MENU/SET to display the menu. Select LANGUAGE (head with speech bubble). Pick your language from there.
Panasonic DMC-FZ200 change language setting
switch on and press menu/set button in set up scroll down until you see a symbol of a face with a speech bubble select this and then select the required language.
the manual
can be downloaded from the following site.http://www.camerauserguide.net/panasonic-lumix-dmc-fz200-camera-users-manual-guide-owners-instruction/14129
i hope this was useful.
Slide the button Set to camera (look the image )
Press Menu Button
Select item and setting
Choose RESET yes /no
select YES and Reset to the default settings.
Or choose LANGUAGE items
and select your prefered languaje,
You camera available English, French, Spanish, Italian, Chinese, Japanses
