How Can I rectify the problems below, #'s+letters"r"doubled(ghosting)
Has slight distortion in top left corner and along bottom of screen. Have been told one of the prisms may be slightly out of alignment and is easily fixed. I wonder how much is the cost to repair it and canI pls ,If I may download the book for this philips rear projection tv? if so where can i download it and how?
Pls reply to [email protected]
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move tCan I rectify the problems below, #'s+letters"r"do - 2c07611.pngdirections your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around Can I rectify the problems below, #'s+letters"r"do - 578ba6c.jpg
Picture of a set that needsCan I rectify the problems below, #'s+letters"r"do - 65af323.jpgchanged.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
