Picture warping and color streaks at corners
10 plus yrs old Hitachi projection
just started
Posted by slavancesr on
Edward
  • Televison & ... Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directipicture warping and color streaks at corners - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
picture warping and color streaks at corners - 578ba6c.jpgtp://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 03, 2009
50" hitachi 10 years old has blue and green colors
Your TV most likely has one of two possible problems.
  • Screen looks 3D
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Dec 12, 2010 | Hitachi 50UX57B 50" Rear Projection...
Ghosting comes and goes
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 01, 2010 | Hitachi 50UX58B 50" Rear Projection...
My set is 10 yrs old. In the upper left and lower
Try adjusting the convergence. If it won't move see below- red IC in particular
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 18, 2009 | Sony KP-43HT20 43" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
I have a Hitachi 50V500A LCD rear projection set. It is 4 yrs old. There is a streak of Blue color running down from top of screen to the middle of the screen. I have changed the bulb but it has not...
This is a very common problem with your model. My best advice is to have a hitatchi authorized service center come out and give you an estimate then call Hitachi and complain to them about the problem. They will useually supply the part for free and you will only have to pay labor to put it in. A good shop will run you $300-$400 to put it in for you.
Oct 28, 2008 | Televison & Video
Hitachi 53UDX10B PICTURE DISTORTION
projection screens are prone to screen burn ,this is caused by the same image being displayed for a long time ie nick jr image in the corner,also check ther are no magnets close to the tv as this will cause distortion,ie speakers etc,hope this helps
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Mitsubishi VS 45501A Projection TV
Model VS-45501A  probably not worth fixing at around 400.00
for a convergence circuit overhaul......T.
Oct 20, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
