SOURCE: red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
SOURCE: sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
SOURCE: Sony KLV-S32A10 32 when i turn on picture come then goes off
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV.
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
SOURCE: Red Power Light Blinking 6 Times
THIS IS HOW I FIX MY SONY TV WITH FIVE BLINKING RED POWER LIGHT.
PULL OUT LAMP - FIND THE INSTRUCTION ON LINE (SONY WEBSITE OR YOUTUBE) EASY
THERE ARE TWO METAL CONNECTION TABS (on top of the lamp) ON THE LAMP. CLEAN THESE TWO METAL FLAT TABS. THESE two tabs MAKE CONNECTION TO THE THERMAL FUSE. IF IT IS DIRTY IT WILL NOT MAKE CONNECTION to the fuse.
CLEAN YOU'RE LAMP WITH A VACUUM. GET ALL DUST OUT.. CLEAN OUT THE TV...THE FAN SUCKS IN DIRT. THIS WILL FIX many ISSUEs. like over heating! dog hair, dust, gets sucked inside the TV by the FAN....hmmmm
ALSO DO THIS TO ALL YOU'RE ELECTRONICS THAT HAS A FAN.
(I FEEL ALL FANS ON ELECTRONICS SHOULD BE REVERSED) but i am sure there is a stupid reason that they want the fan to **** air inside the electronics. Like hmm
THIS cleaning SHOULD BE DONE EVERY 6 MONTH
