How to stop it from leaking?
Depends on source of leak:
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
http://waterheatertimer.org/Leaking-water-heater.html
Some leaks can be repaired, while other leaks indicate that tank is rusted and needs replacement.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: GE Profile Smart Water Heater leaking at top/no hot water
Hi, has your problem been solve yet? please respond
Thanks
SOURCE: elec water heater no hot water
Check the breaker to see if the unit is getting power. You will need a voltage meter to check out the thermostat on the unit and also you will need to use it to check if the elements aren't blown. Sounds like the unit isn't getting power but could be the thermostat located under one of the panels on the side of the unit.
SOURCE: GE Smart Water Heater - Model #GE40M06AAG - 40
There should be a faucet on the side . you hook up a garden hose and drain it.
SOURCE: I have a ge smart water electric water heater and
does it not have adjustments for heat settings. I thought these were smart as in maintaining heat with demand
