I came home to hear the water heater with a hissing sound...didn't think much of it until the next afternoon, it was still making a hissing noise and I noticed the pipe that goes thru the wall to the outside was leaking, rather heavily...there is a sort of relief valve on top of the heater and when I lifted it, warm water leaked out and about 2 minutes after that, the water stopped leaking out of the pipe outside...does anyone know what this could be or am I able to fix this problem....my water bill will be thru the roof otherwise :(
Bad relief valve or too much pressure in the tank. Does water heater system have a pressure blotter tank that allows for expansion(an expansion tank)
Posted on May 05, 2017
SOURCE: GE Profile Smart Water Heater leaking at top/no hot water
Hi, has your problem been solve yet? please respond
Thanks
Posted on Nov 23, 2008
SOURCE: Relief valve constantly releasing water.
lower your thermostats a bit. If your temperature is set to the hottest setting, then chances are no relief valve will do
Posted on Jan 08, 2009
SOURCE: GE Smart Water Heater - Model #GE40M06AAG - 40
There should be a faucet on the side . you hook up a garden hose and drain it.
Posted on Nov 18, 2009
SOURCE: Rheem water heater Model 81v40DT
It sounds like the pressure/temperature relief valve is stuck open slightly, and draining out the PVC pipe. This is common in poor water locations.
You can try lifting the release on the top and letting it pop shut again, but chances are good that by now the seat has been destroyed by the water passing over it. Replacements are available at any home store, just remember to drain the water out of the heater so you don't flood the garage. MAKE SURE YOU TURN OFF THE POWER FIRST OR YOU WILL BE REPLACING THE ELEMENTS ALSO! You will need to wrap the threads with teflon tape before installing the new valve.
Posted on Mar 30, 2010
SOURCE: we have a leaking water heater.
As far as a shut off valve on to the water heater, if there is one you should be able to see it on the water line going to the heater. This is not common in mobile homes. If there is not one I would strongly recomend you install one when you replace the heater. If it is going to be a while before you replace the heater you might consider draining it and cutting into the inlet line and installing a shut off valve, so you can turn the house water back on. I hope this helps.
Posted on May 13, 2010
Apr 16, 2013 | RTO Atwood Water Heater - 6 Gal LP
Sep 07, 2011 | Premier Water Heaters
Sep 05, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Jul 11, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
May 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Mar 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Jan 05, 2010 | RELIANCE ELECTRIC WATER HEATER
Sep 29, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Feb 16, 2009 | General Electric GE SmartWater Household...
Jan 14, 2021 | Noritz Water Heaters
480 people viewed this question
