HOW YOURESET A SAMSUNG DVR SHR 1040
I believe there is a small hole on the face of the unit. power down the unit and incert a straighten paper clip to push the reset button, power up the unit wait 30 seconds and it should reset. if that does not work get back to me.
mj
SOURCE: SHR-1040 Samsung DVR
It does the same thing to me....Can you imagine sitting there viewing the whole hard drive just to see what happen 39 minutes ago. This Samsung DVR is stink.....believe me ...Every problem I read on here,,Im have the same..
SOURCE: samsung shr 1040 4 channel dvr
I think I can offer a solution. The unit is set up from the factory with television input enabled. You'll need VGA input enabled. Hook it up to a TV; go to setup in the menu and enable VGA. Then you'll be able to use your monitor.
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
SOURCE: I forgot my password and I cannot do anything.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
SOURCE: I am looking for the Samsung SHR-1040 Users
I think this is what you are looking for.
User Manual (ver.1.0) for Samsung SHR-1040/XAA
Please be sure to rate my help. :-)
