Question about Samsung 4 Channel Dvr
Samsung shr-1040 My SHR- 1040, when I connect the power I feel the hard disk and fan start, but the leds (power, alarma, hdd, rec) in the front panel don't start its like if turn off.
Posted by camiloreyes on
  • skymike May 13, 2009
    I have a Samsung shr 1040 for about 3 years. I am getting live pictures on the 4 channels, but is not recording. I cannot access the recorder to erase the HHD. The password I have does not work. The blue power light is solid, the green hdd light is flashing, and the red record light is solid. I cannot access to view recordings. Help. Mike
  • andi99rus May 25, 2009
    After unplug device in record mode have same problem. I am getting live pictures on the 4 channels, but is not recording. Buttons and remote does not work. Blue power light is solid, other not light.
Anonymous
  • 80 Answers
Most likely you have a bad board. try resetting the unit if this works great if not then you will have to send it in to be repaired.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Posted on Sep 07, 2009
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: I forgot my password and I cannot do anything.
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is ‘4321’., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Posted on Jul 09, 2009
Anonymous
SOURCE: samsung shr 1040 4 channel dvr
I think I can offer a solution. The unit is set up from the factory with television input enabled. You'll need VGA input enabled. Hook it up to a TV; go to setup in the menu and enable VGA. Then you'll be able to use your monitor.
Posted on Aug 24, 2007
ron351
Ron G
  • 14 Answers
SOURCE: samsung shr-1040
Best to get a USB thumb drive and download the video needed to the thumb or flash drive. Put it on the computer and there you can use a program like Snagit to capture the best parts and save it for police. Saves a lot of wasted time
Posted on Oct 28, 2007
Anonymous
SOURCE: shr-1040, password fail
mode key + ch2 hold down 10 seconds factory reset password to 4321
Posted on Aug 15, 2008
Anonymous
  • 1011 Answers
SOURCE: Need a user manual for the shr-1040
Click this link for manual download
Thanks Good Luck
"Rate the Solution as FIXYA"
Posted on Feb 24, 2009
1helpful
Samsung SHR-1040 Won't Initialize
try to reset the unit and start over.
Mode Key + CH 2
default value.
mj
I changed the passwors of samsung shr-1040
Mode Key + CH 2
default value.
mj
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
SAMSUNG DVR SHR 1040
I believe there is a small hole on the face of the unit. power down the unit and incert a straighten paper clip to push the reset button, power up the unit wait 30 seconds and it should reset. if that does not work get back to me.
mj
4helpful
2answers
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
The samsung monitor ssc21web shows system initialize... the three periods blink
ssc21 web does not work, It was a cameras shut down it says LA and AL why
7helpful
3answers
Clock battery has failed
Yes, I can to slove this problem.
I'm not english people then excuse me for my english. You need a telnet software type hyperterminal in Windows XP, a PC with serial port and a pin-to-pin serial cable. For frist time you need replace the internal battery CR2032 3V of SHR-2042 and erase all content of Hard disk. If you can't erase HD is not a big problem
Connect SHR-2042 with serial cable, open Hyperterminal and create a new connection using this setting:
Speed = 115.000
Bate bit = 8
Parity = nothing
Bit stop =1
Floe control = nothing
Save connection and run it.
Power on shr-2042 and set time and date.
Type "help" for command list
mor more istruction contact me [email protected]
2answers
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Samsung 4 Channel Dvr Logo
Top Samsung Home Security Experts
Mike
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
