Lands Phones Logo
Anonymous Posted on Aug 05, 2013
I need user's manuel for intercom masterfono A/005
  • Anonymous Aug 07, 2013
    I want the user's guide to install intercom 'model masterfono A/005" at home
Model 3287W Genesis Jet steam cleaner- user manual.
Contact a vendor in South Africa.
Cnr Witkoppen & Riverbend rd (Entrance through garage), Randburg South Africa
[email protected]
0860 005 005
https://verimark.co.za/index.php/genesis.html
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Manuel and remote control
The GameChanger ESPN Remote Control codes for an Emerson VCR (only, no combo with DVR) are
Emerson 003, 004, 005, 064
2answers
1helpful
2answers
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
2helpful
2answers
Our intercom on the phone will not turn off and we have not been able to find the manuel.
We had the same problem...Each phone line needs to have a separate phone I.D. You probably have two phones with the same number or one phone does not have a number assigned to it. You can do this automatically. Press menu, phone options, then phone I.D. and press select and the system will automatically assign an I.D. to the phone. Do this for each phone on your system and the problem should be solved.
If you want to "make an announcement" using speaker phone using intercom, how do you do it
When you intercom the extension, insert a STAR ("*") before the extension number.
EX:
Dial intercom 12, will ring 12.
Dial intercom*12, will page the phone and go straight to speakerphone.
IF the far end user has their "MIC/HFAI" button lit, they will need to do nothing, they can just talk.
IF not, they will need to lift the handset, OR, press the "MIC/HFAI" button, to be head.
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
1helpful
2answers
Intercom
Each of the six phones must have line 1 connected to the same "subscriber loop" (the same phone number). Assuming this is the case, and that you have not assigned any numbers to the the top six speed-dial buttons, each station will have agreed to be assigned a station number.
From any station, pressing the speed-dial button for another station's station number will page that station.
Now, how to properly initiate an intercom conversation differs between announcing to another station that a call is on hold, or a "cold call".
Top RCA Lands Phones Experts
k24674
SmartAviator
SmartAviator
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
