Video Cameras Logo
Anonymous Posted on Sep 14, 2017
Carcam HD car DVR and seems to record in 2 minute segments. My 50 minute trip creates 25 or more files. I've tried changing settings to loops off, 10 min loops, continuous 10 mins, and camera seems to do the same thing. Perhaps a glossary on the meaning of "loop" settings and "continuous" settings? Even tried reset, no change. Also, what does "motion" on/off do?
Tony Parsons
Level 3:
  • BrainyTrade Master 6,405 Answers
  • Posted on Sep 14, 2017
Tony Parsons
BrainyTrade Master
Level 3:
Answers
6405
Questions
Helped
1652405
Points
20272
Look in the manual or consult the mfrs website for advice
5 Related Answers
Anonymous
  • Posted on Jun 28, 2008
SOURCE: Panasonic NV-gs50
where can i get drivers for the NV-GS50
Anonymous
  • 185 Answers
  • Posted on Feb 01, 2009
SOURCE: DVD recorder continually stuck on a loop trying to read disk.
Hi again
I am so pleased to hear that you have restored the DMR E55 and for taking the trouble to let me know. It's always satisfying to achieve something like that and I guess you'll get even more pleasure from using it now than you did before. They are good machines and well worth the effort to keep them going.
Thanks again and kind regards
Anonymous
  • Posted on Aug 06, 2009
SOURCE: Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Anonymous
  • 4088 Answers
  • Posted on Oct 28, 2009
SOURCE: why does my washing machine trip the electric
Someone with a wattmeter needs to read the wattage load by the machine when washing. If the running load is greater than the rated load of the machine, then the problem is likely the motor itself or the drum bearings are going bad. If the electrical load is normal, then the breaker in the house electrical panel is either under-rated, or the breaker is defective. If the breaker is a 'ground fault' type, the washer may have current leakage to ground causing the breaker to trip. Another possibility is that there is another outlet that is on the same circuit and the combined load trips the breaker. Shut the breaker off and try any other sockets in the area to see if they went dead too. Hope this helps!
bob_priddy
  • 4 Answers
  • Posted on Jan 05, 2010
SOURCE: humax digital recorder picture freeze every 10 minutes
Humax are having problems and are starting to send out software upgrades (night-time updates) - seems to be related to the new formats on the MUXs for the digital switch-over. Our 9150T hasn't been fixed yet but due any day (I hope)
1helpful
After I watch a 1-hour HD recorded program from my DISH DVR and erase it, the amount of HD time I have left on my DVR does not rise by 1 hour.
Contact the company that supplied it and ask if there is a 'defragment' or 'compact' feature hidden in settings or service procedures?
When I record programme from the tv it always cuts of at least one or two minutes before the end of the programme is there any way to fix this
Try setting the time of your DVR to be precise. If the recording starts 2 minutes before the show starts it will cut off 2 minutes before the show ends! My DVR has functions that allow me to add a minute or two before or after the times set to record, but that can cause other problems like if you are recording 2 shows and you try to record a new show after a show that was being recorded, it won't allow you to, because it can only record 2 shows at a time! Best bet is tro synchronize your watch to the Internet time and use that to sync your DVR time.
Changing the clock/internal time
The clock settings should be set to Auto so that the clock is set by the broadcasted signal; this will automatically update when the clocks change.
Note that Recording start and end times should be set to On Time to ensure that the broadcaster's start and end signals are used. If either of these are changed, the timing becomes manual, and functions such as Series Record are not available.
Details I record drum/ bass and synth loops into logic and then send them to the rc50 loop pedal, i had 50 seconds of recording time left so i added a new track which left me 25 seconds of recording t
Likely the memory is fragmented into tiny snipets much like hard drives get. For looping, the memory likely has to be contiguous chunks. Clear the memory and load each in sequence.
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 • Boss Rc 50
Dish dvr 622 will not record two shows at once
Deborah Haviland,
I can understand the concern with that receiver not doing the 2 recordings. There isn't a specific setting that stops it, so the receiver itself may be having trouble. Unplug the receiver for 10 seconds and plug it back in.
If the problem persists we would have to replace the receiver. If you can send me an email at [email protected] with the account or phone #, I can definitely check into that with you.
Tommy Faust
DISH Social Media Representative
Optical input from Sony PS3 Playstation.
Have you tried setting the PS3 on linear PCM output instead of bitstream? The DVR 50 may not say Dolby Digital since the optical cable goes directly from the PS3 to it but you may get the surround channel output you're looking for.
Top BrainyTrade Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a BrainyTrade Video Camera Expert? Answer questions, earn points and help others
