Maytag MGR5765QDQ CleanDesign Gas Kitchen Range Logo
Posted on Apr 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I utilize the self cleaning part? Do I just press ''clean
Do I not need to select a temperature?  Thank you.  M
Anonymous
Level 2:
Sergeant:
  • Expert 291 Answers
  • Posted on Apr 01, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
291
Questions
0
Helped
93320
Points
784
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Viking VESO 530SS Oven. Self clean light flashing.
Question edited for clarity.
The whole idea of Self Clean feature is to keep the makers into steady sales of spare parts. The components can only tolerate those temperatures for a number of cycles before elements, door locks and control boards start failing. Consumers don't realize the heat involved!
between 800°F and 900°F Self-cleaning ovens bring the heat so you don't have to spend hours scrubbing. Traditional self-cleaning cycles heat the oven between 800°F and 900°F, helping turn soil and spills to a powdery ash you can then wipe away. They utilize only heat-no chemicals-and are built to withstand high temperatures. (except they aren't)
Either the door lock has failed or the control board has failed.
https://www.justanswer.com/appliance/6r72n-own-viking-dual-fuel-vdsc530-range-oven-will-not.html
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Service https://www.generalappliancesvc.com > why-you-shou...
Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipedia https://en.wikipedia.org > wiki > Self-cleaning_oven
A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ...
Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CA https://fixappliances.ca > 4-reasons-stop-using-self-cle...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to aid in ...
How Self-Cleaning Ovens Work · ‎Major Parts Damage
How do I cancel a delayed start when trying to use self clean on Kenmore oven 807189701 Rev B
Unplug the power and cancel it. Never Ever use the self clean feature. We see damage here every couple of weeks. The worst was a burned control board on an oven that all parts were obsolete, so the self clean cost a thousand bucks!
Self-cleaning ovens bring the heat so you don't have to spend hours scrubbing. Traditional self-cleaning cycles heat the oven between 800°F and 900°F, helping turn soil and spills to a powdery ash you can then wipe away. They utilize only heat-no chemicals-and are built to withstand high temperatures. (Says Maytag who love selling elements, door locks and other parts),
Self-cleaning oven
No heat on convection or self clean
If you have been using the self clean feature, you have probably burned out or damaged the connections to the fan and the convection fan element or thermistor. NEVER EVER use the self clean feature.
https://www.partselect.ca/Models/CGEB27S7CS2/Sections/BODY/?ModelID=1073773&ModelNum=CGEB27S7CS2&mfgModelNum=&ManufactureID=4&Selected=OTRVH5GS&Position=1&mfg=Frigidaire&Type=Wall%20Oven&Mark=1
4 Reasons to Stop Using Self-Cleaning Oven Feature ...
https://fixappliances.ca > 4-reasons-stop-using-self-clea...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or 500 C°) to ...
How Self Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Why You should Never Run A Self Clean Oven Cycle & A ...
https://www.generalappliancesvc.com > why-you-shoul...
Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) .....
How do I operate my self-cleaning oven..no manual..
Thank you for your post, Pattie Cromie!
I see that you would like to operate self-clean on your Frigidaire range and you do not have the manual. Typically, to start self-clean you would need to push the button labeled "Self-clean" and make sure there is nothing inside the oven before starting a self-clean cycle. Also before starting self-clean close the door because of the temperatures that are created within the oven the door needs to be closed and locked. I hope this has been beneficial. -Matt
Kitchenaid oven racks fall
I am a bit late on this question, but just ended up in a rabbit hole of unanswered Kitchenaid questions
The self cleaning features only serves to keep manufacturers in steady sales of parts. Quite simply the oven can only take those temperatures a few times until they break. The heat burns out elements, damages fans, door locks and worst of all damages control boards which are not far enough from the heat source. You problem sounds like the walls of the oven have buckled in the heat so the racks no longer fit. Too late now, but you should have taken Kitchenaid to court, the oven was not fit for purpose under the description they used to sell it to you.
Never use the self cleaning feature as stated here
https://www.google.com/search?q=self-cleaning+oven+temperature
General Appliance Servicehttps://www.generalappliancesvc.com > why-you-shou...
Self-cleaning oven
Wikipediahttps://en.wikipedia.org > wiki > Self-cleaning_oven
FIX Appliances CAhttps://fixappliances.ca > 4-reasons-stop-using-self-cle...
I can't find a button marked self clean on my crosely oven. Can you send me a picture of which button I use and instructions for self cleaning. Thank you Kellyann Waye
1. move door to locked position
2. Press self-clean pad.
3. press up or down to select clean time (it will flash 3:00)
4. if you wish to delay the start of cleaning press a. stop time b. press the up button on pad to select the time of day then press clock and time of day will reappear. Press stop time pad to recall the time you set.
5. When the oven turns on the oven on indicator will light. Internal lock will engage and door cannot be unlocked.
6. About one hour after the clean cycle ends, the lock indicator will turn off. The oven door can be unlocked and opened.
** to cancel press cancel.
Hope that helps!
The select clean button doesn't seem to be working when i press it. how do i utilize the self clean function?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Our over will not start the self clean....the monitor beeps with the message door.....
Try pressing in on the handle while you select the cleaning cycle.
It's saying that it cannot engage the safety lock which it needs to do before cranking up the temperature to the ~900 degrees needed to start the catalytic action that does the cleaning.
If the door isn't adjusted well, the lock may not be able to disengage either when the temperature has dropped to a safe level.
Before you try pressing in the door, check around the edges of it to make sure the spacing is the same around it. If you can see discernible differences from left to right or the top isn't close enough, the door may be slightly twisted.
Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Oven not working
    15
    problem
    8. door will not open.
    9. oven will not heat after Self cleaning.
    possible Cause
    oven is in Self-clean mode.
    time of day is not set due to power failure.
    oven settings are not correct.
    remedy
    if oven is hot, door latch will release
    automatically when oven temperature
    falls below 390˚F at end of cycle.
    if Self-clean was just selected
    and the oven is still cool, press
    “caNceL•SecuRe” to turn off Selfclean.
    the door will open in about 30
    seconds.
    Press “cLock” touch pad, then press
    “tiMe•teMP” pad to set correct time of
    day.
    follow mode selection and clock settings
    as specified in the oveN oPeRatioN
    section.
    oven will turn on automatically
    at preset time. if desired, press
    “caNceL•SecuRe” touch pad to cancel
    out of delay timed mode.
    Troubleshooting Guide (Continued)
    Important:
    If a Failure Code is displayed, the oven will beep continuously until the user presses the “CanCel•seCure” button. the oven will not heat
    after a failure. Call a qualified appliance technician to repair the oven.
    Oven Failure Codes
    Clock Display Cause
    f0. touch pad is stuck in depressed position.
    f1. Relay circuit failure.
    f . oven temperature exceeded the clean runaway temperature (Self-clean mode
    only) or the cooking runaway temperature (cooking modes only).
    f3. Short circuit in the oven temperature sensor.
    f4. open circuit in the oven temperature sensor.
    f6. failure in the eePRoM check comparison. (only time of day and timer will
    operate.)
    f7 failure of the Self-clean automatic door latch circuit.
    f8. failure of the door latch motor. occurs when the motor runs for two minutes
    without the door locking in Self-clean mode.
    befOre yOU Call fOr servICe
    No maintenance, other than the Care anD CleanInG
    InstruCtIons identified in this use & Care manual, should
    be attempted by the owner/operator. all other maintenance and
    service must be performed by a qualified appliance technician.
    first, review the recommended checks listed in the preceding
    troubleshooting Guide. then, be certain that the appliance has
    been installed properly and is being operated correctly. familiarize
    yourself with the warranty terms and conditions listed in the
    proDuCt WarrantY section.
    if the above checks have been completed and the problem has
    not yet been remedied, call your local authorized dacoR®
    service representative. your dealer can normally provide the name
    and telephone number of the nearest service company.
    prOdUCT maInTenanCe
    If yOU need servICe...
    dacoR® works diligently to ensure your satisfaction when
    service is necessary. However, if you are not completely satisfied
    with the service provided, contact the company that performed the
    service and express why you are not pleased. Normally, they will
    be willing and able to resolve the problem.
    if the service agency is not able to respond effectively, call or
    write the dacoR® customer Service department. the phone
    number and address of this department are listed on the inside
    front cover of this manual. Please include your telephone number
    if you choose to write. we will then do our utmost to assure your
    happiness and satisfaction.
    Here is a snipet from www.dacor.com
    You can view the manual there by enter ing your oven model number.
    Top Maytag Kitchen Ranges Experts
    vince
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
