Thank you for your post, Pattie Cromie!
I see that you would like to operate self-clean on your Frigidaire range and you do not have the manual. Typically, to start self-clean you would need to push the button labeled "Self-clean" and make sure there is nothing inside the oven before starting a self-clean cycle. Also before starting self-clean close the door because of the temperatures that are created within the oven the door needs to be closed and locked. I hope this has been beneficial. -Matt
SOURCE: self cleaning oven
here is the link where you can download the owners manual for your stove.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200919en.pdf
you may have to copy and paste this into your browser. and it may take it a min to load.
please do not forget to rate and comment about your experience today on fixya.
SOURCE: Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
SOURCE: Frigidare double convection self-cleaning oven
try here kim if you dont find what you need contact me back http://www.frigidaire.com/support/manuals.asp
SOURCE: We have a relatively new fridg 30
I have the file for you if you need to me to send you the manual..
Thank you again for using fixya
SOURCE: The oven was cleaned with oven cleaner instead of
It is safe to use. Make sure you let it run for about 20-30 minutes at 350 before putting any food in it, this will burn off the residue. Also before starting it make sure you didn't get any cleaner on the heating elements if so wait for it to evaporate before using.
