I have a RCA TV that needs a remote I can note watch DVDS cause I don't have the remote that came with the TV it is a 1992 home theatre sound retrieval system. I look behind the TV to see the model number I did not see the first to letters this is all I have 5100st.
Universal remote control codes to check with RCA TVs are 1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205. Either buy one original remote control, or buy any universal remote control, which have the set-up codes stated above in its code list. If you wish to get more details about remote controls, http://electrohelponline.blogspot.com/
SOURCE: rca home theatre big screen tv
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
SOURCE: Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
SOURCE: Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
SOURCE: I have a ds25390 sanyo tv and can not figure out
you can test your tv on a different tv. and a/v cables togather. yellow is video- white /red are for sound.
okay
SOURCE: I need code numbers for a RCA Universal remote.
018.042.049.152.try these three digit codes one at a time.
