How do I fix my 99 blazer the dome lights won't turn on and the 4 who drive won't light up or work
In the instrument panel fuse box fuse # 8 CTSY LP 10A ,that's for the dome lights, fuse panel is left side of IP. What are you talking about 4 who drive won't light up or work ? 4 wheel drive ? Do you have two speed automatic or two speed selectable ?
Switch Indicator Lamps Do Not Light - One or More ? Check fuse #15 IP fuse box 10A 4WD . This is for two speed auto !
Circuit Description
The indicator lamps circuits consist of 5 individual lamps contained inside the mode/range switch assembly, they are AUTO, 4WD, 2HI, 4HI, 4LO and NEUTRAL. The AUTO, 4WD, 2HI, 4HI, and 4LO lamps are contained inside their respective range button. When the ignition is ON, the transfer case shift control module illuminates the indicator lamp that corresponds to the current ATC gear position by providing a ground through a current limiting driver.
The transfer case shift control module flashes each indicator lamp after a shift has been requested and will continue to flash until the transfer case shift control module can complete the shift. After a shift to AUTO, 4WD, 2HI, 4HI, or 4LO is made, the transfer case shift control module will flash that indicator lamp until the transfer case shift control module receives a high voltage signal on CKT 1695 from the front axle switch.
A solid state circuit located inside the switch supplies ignition voltage to the lamps. The solid state circuit also receives voltage whenever the headlamp switch is in park or headlamp position. When the solid state circuit receives voltage from the headlamp switch it will reduce the voltage that it supplies to the indicator lamps, dimming the lamps when the headlamps are ON.
fuse holder for Dremel motor speed control is broken- will not hold fuse in: therefore the speed control will not work
