SOURCE: amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
SOURCE: confused
Hi jimmyjames, How do you have the wires hooked from the sony reciever to the inputs on the mtx? Sounds like your Remote wire is way too big. it should be 14 guage. It only sends a low voltage low amp signal. Another thing that could be messing up the sounds is the routing of the wires. you should have the power supply wires separate from the Audiop signal wiring. Power should run down the Driver side and Audio down the passenger side. When you answer I may be able to tell you more.
SOURCE: Amp Not working!
If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
Let me know if you have any other questions.
Hi Trim God,
I do not reccommend that you push the Pioneer speakers over 100 watts. The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away . Hook up the pioneers straight to the Channels,. do not bridge. I put Subs in my truck though. I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub in my Z28. The pioneers never get drowned out. I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
