Question about MTX (SLH-T7512X2-A) Car Speaker
How can i bridge a mtx 9500 using a mono amp?
How can i bridge a mtx 9500 sub using a mono amp?
Anonymous
    Scholar:
    New Friend:
  • 66 Answers
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
Posted on Apr 08, 2010
Testimonial: "yes that really helps thank you very much."
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
Just hooked up mtx 500d mono amp and 12 inch sub worked for a 1/2 hour then sub quite and led on top of amp just flashes.
either ur ohm load is way off ur pos n neg might be touchin or more than likely u blew u sub is it scratchy when u push in the middle of the cone ? does it push in at all?
May 14, 2010 | Car Audio & Video
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
I'm planning on installing a system in my pick-up and I was hoping I could get a little assistance. I was planning on using a pair of 5'' McIntosh ms486 coaxial speakers (120w max 4 ohm)in the front doors...
First of all use the larger output amp to power the sub. You can tell if its free-to-air if in the middle of the magnet there is a hole for "air" to flow freely. The advantage of free to air is they dont require much of an enclosure or next to none so you can mount it on a single piece of mdf wood and use the cab in the truck as an enclouse itself. I would bridge the amp for the sub to mono but be careful to tune so you dont "distort". Secondly the amp for the mid's shouldn't be bridged any maybe you could run the front and rear speakers off the same amp.. I would get an amp for rear and front speakers each and one for the sub. Your ouput rca's should goto the cross-over first then to the amp (sub) - then wired to your sub (mono) which is bridged. Ensure to tune your cross-over to lowest frequency for sub. Its easy to bridge an amp if its 4 channel.. looking at the speaker terminals it will look like ( + - + -) use the two outer most terminals to bridge to mono.
Sep 13, 2009 | Sony Car Audio & Video
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
Picking the right amp.
yes you could go with a 2 channel. You could alwayse bridge it.
Jan 07, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Directed 1100d 2-channel amp
You will bridge the amp, and if the subs are all 8 ohm subs, you can probably wire them all in parallel, if they are all 4 ohm subs, you would wire then in series.
Oct 17, 2007 | Directed 1100d Car Audio Amplifier
MTX (SLH-T7512X2-A) Car Speaker Logo
442 people viewed this question
Top MTX Car Audio & Video Experts
Marvin
Marvin
Rob Beech
Rick Wrieden
Rick Wrieden
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
