20 Most Recent MTX (SLH-T7512X2-A) Car Speaker Questions & Answers
Actually, you could be in luck.
If you are getting 'absolutely nothing', it could be something simple. Open it up (carefully) and make sure the wires are secure on both the speaker and the inner connection leads.
I've come across several this has happened to that were brand new.
Good luck
Mike
MTX... | Answered on Jul 29, 2010
nice way to ask something :) you must open the subwoofer box and check the connections. the problem is bad contact. with cold all metals shrinks and with warm they expand and make contact.
Don´t forget to rate.
Thanks
MTX... | Answered on Jun 17, 2010
You cant bridge it to the MONO AMP . You can only bridge subs & speakers to 2 CH & 4 CH AMPS that are bridgeable. Because if it appears that there is 2 channels on a Mono amp its so its convenient for you to hook up 2 4ohm subs to it easily But both channels are actually connect internally together in parallel inside the amp unlike a 2 channel they are separate.
So just connect your mtx 9500 to a plus and a minus and doesnt matter which since all the + terminals of are connected together and - are connected together already.
Whats important is on the side of the sub/box it reads 2 ohms. The lower the ohms the more power the Mono amp will put out. Mono amps are designed to handle 2ohm loads.
If it reads 4ohms The MONO amp is the wrong amp to use cause the power will be weaker. So if you have a 1000 Watt Mono amp at 4ohms the sub will only get 500 WATTS Max while a 2 ohm will get the full 1000 Watts.
If it reads 4 ohms connect it to a 2CHANNEL AMP and BRIDGE IT (connect + of the sub to 1st channels positive of the amp then connect - of the sub to 2nd channels negative of the amp) . The power will be doubled when you bridge it on a 2 channel amp. NOW if it was a 2 ohm sub and you bridged it to the 2 channel amp it will fry the subs and ruin the amp. 2 CHANNELS CANT TAKE A 2OHM LOAD BRIDGED OK.
MTX... | Answered on Apr 08, 2010
power to-battery plus
ground;;
remote''
MTX Car Audio &... | Answered on Nov 05, 2019
THE GREEN LIGHT SHOULD SHOW WHEN AMP IS POWER UP AN RED WHEN IN PROTECTION MODE
MTX Car Audio &... | Answered on Sep 12, 2019
Try eBay Often available there from private sellers
MTX Car Audio &... | Answered on Aug 25, 2019
I was having a similar issue. I checked every wire from the battery to stereo to amp, checked the ground, pulled the stereo to double check the wiring was all correct. Everything seemed good so I thought it had to be my battery not putting out enough power. Tested it and it was good. What it turned out to be was the connection from the power cord to the battery. It had a tiny bit of built up corrosion that was making the amp go into protect mode. Cleaned it up and hooked it back up and has been golden since.
The link attached is pretty straight up on what you need to check for different circumstances. I'm guessing it's a low voltage issue. Good luck
MTX Car Audio &... | Answered on Aug 23, 2019
Check the wiring 1st then go down the line...Check speaker connections..Look at your power,ground and remote wire hook up
MTX Car Audio &... | Answered on Oct 18, 2018
Since this is a vintage item, the cost is whatever the market will bear, wherever you're trying to sell it. I would suggest checking current prices on sites such as eBay, where one is currently being offered to sell at $200, while another is being offered for $90. The perceived value is what determines the selling price at this point, because the MSRP is long irrelevant by now, being that it's a discontinued item.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
MTX Car Audio &... | Answered on Jul 08, 2017
MTX (SLH-T7512X2-A) Car Speaker Logo
4 questions posted
Top MTX Car Audio & Video Experts
Marvin
Marvin
Rob Beech
Rick Wrieden
Rick Wrieden
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • MTX Car Audio & Video
Most Popular Question
subwoofer only works when weather warm
  • Car Audio & Video
