Vehicle Parts & Accessories Logo
Anonymous Posted on Jun 02, 2013
Window fuses the fuse keeps blowing
Hashim Khan
Level 2:
Scholar:
  • Expert 148 Answers
  • Posted on Jun 03, 2013
Hashim Khan
Expert
Level 2:
Scholar:
Answers
148
Questions
0
Helped
41884
Points
417
Try spraying silicone lubricant spray in the glass channels (rubber beading thru which glass run up and down). If this stops fuse issue then you need to change those glass beadings.
Issues with a Fuse - 2003 Chevy Trailblazer
check switches and wiring harness for short
Power windows in 2003 jeep liberty limited keeps blowing fuses. No sound when I try to use any window. Put new fuse in, it works for 2 days then blows again.
When you change the fuse and it blows in 2 days, are you using just one window or are several windows used during that 2 day period. If it is just one window then the motor may be bad and drawing to much voltage or shorting out and that is what blows the fuse. I would use just one window during a 1, 2, 3, or 4 day period. If the window used does not blow the fuse try another window and go through the same process of elimination. If a particular window use blows the fuse I would pull the door panel and check for a wire that might be bare and during your drive may be touching metal and creating a short and blowing the fuse. No matter what you have to do some tracing to locate where the bad motor or bare wire might be.
30 amp starter fuse keeps blowing on 98 cherokee
you may have a short (verify the integrity of the insulation of the positive wire from that fuse going to the rear window defroster, check the relay & switch.) try to replace the relay.
Power window fuse burns out on mercedes 1987 190d
Get yourself a wiring diagram & test the system
to find a problem,failed component or wiring causing
the fuse to blow
1helpful
Fuse keeps blowing
Could be number of causes: faulty (shorted) window control switch, damaged corroded or shorted wires to windows, faulty control unit (stuck relay), faulty window motor/s, exposed supply wire shorted with body or something else...
Nov 01, 2013 • GPS
01 FORD F150 STYLESIDE CREW WINDOWS AND WIPERS WILL NOT WORK. BLOWING FUSES
I would check for traces of water that have leaked into the inside fuse panel. You can sometime see rust marks on the metal parts of the dash around the fuse panel. There is a module on the back of the fuse panel and wire connectors that you can remove and inspect for water. If you find water in the fuse panel...the module and fuse will need to be replaced. If no water is found...the circuit that keeps blowing the fuse will need to be traced for a short. I could not find any common circuits for the wipers,power windows or lights.
Power window fuse keeps blowing
If a fuse keeps on blowing there are broken wires or a short in the circut controling them.
1helpful
I have a 1997 mercury mystique and the power window fuse keeps blowing. What could be the problem?
When a fuse keeps blowing the problem is usually a short or open circuit that allows for the current to keep passing and blows the fuse
2answers
Passenger windows/ power seats fuse keeps blowing
Check the seat wiring harness below the seat and under the carpet. Water and moister will cause it to rust and break the wires or short them out. The windows and power seat require the use of a circuit breaker, this is recommended.
When trying to go up my window fuse keep blowing out
IF ITS ONLY THAT ONE DOOR THAT BLOWS THE FUSE TAKE OFF THE DOOR PANEL AND LIKE YOU SAID CK TO MAKE SURE NOTHING IS RESTRICTING MOVEMENT IF EVERYTHING A-OK REPLACE THE MOTOR SOUNDS LIKE ITS HAD ENOUGH AND IS PULLING TO MANY AMPS THATS WHY YOU KEEP BLOWING FUSES GOOD LUCK HOPE THIS HELPS
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
