Question about Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011
I have a ml350 mercedes ,,trunk won't open
Trunk won't open
Posted by JEAN BURRELL on
K. Tony Malvar
    Problem Solver:
  • 38 Answers
All new model cars are built with a manual release inside the trunk it glows in the dark and is lime in colour Lower the rear seat back shine a flash light in there find the manual release and pull it down Trunk will now open Check the lock striker to make sure it isn't obstructed then also look at the rubber knobs to see if they are not turned up too high which would keep the trunk from opening with the remote You can always use the key to get in there The key is inside the bottom of the key fob Just look for the little clip on the bottom of the remote to release the key inside
Posted on Apr 24, 2014
How to replace the trunk/lift gate hydraulics on 2011 ml350 mercedes
Normally all you have to do is prop up the hatch, disconnect the electric connector from the strut(s), remove the struts from the hatch and the body.
Try a Mercedes bulletin board rather than FixYa
Oct 22, 2017 | Vehicle Parts & Accessories
Hit n rear bumper
usuallt the reset buttton is in the trunk on most cars.
Jul 29, 2014 | Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome...
MERCEDES ML350
Try opening the trunk using the same key used for the ignition.
The key hole is next to the passenger side taillight
Are you gettin a "trunk ajar" light and the trunk is closed? If so, probably the indicator switch is defective. It's on the inside driver's side of the trunk. (The remote will not work if the trunk is open or if the switch is defective & not contacting the stopper properly.)
Apr 23, 2014 | 2000 Lincoln LS
Trunk door latch power lock. How to stop the noise from the trunk door
it sounds like you have a loose fitting trunk lid, in which case you will have to loosen trunk latch and adjust it so it can seal tighter on weather stripping
Mar 25, 2014 | Mercedes M-class Ml Ml350 Ml550 Ml63...
Mercedes Benz ML350 lift gate Will not Open
Have you tried taking the lift gate panel off? If you do, get some white grease and lube the mechanism.
Sep 17, 2013 | Air Conditioning and Heat for...
Trunk lid pull down motor
you must go to some junker for to buy the motor . Search the internet and look for them. I can recommend many in area of Miami, Fl.
God bless you
Jul 15, 2013 | Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome...
My mercedes ml350 won't sart..when i turn the ignition it makes a sound but the engine won't start
I don't know if this is helpful but an engine needs three things to work. Air, fuel, spark.
Jan 15, 2013 | 2006 Mercedes-Benz ML 350
Mercedes S430 trunk won't open
you have to stick the key in the trunk and turn it to the lefy while hittin the unlock button on the key pad 35 times has to be 35 and it will unlock. my battery died and it locked the trunk as u know i coudn't jump it cause the battary is in the trunk haha but yeah 35 times while hitting the key. mercedes wont tell u but my buddy works for inskip and filled me in your o so welcome from one s430 owner to another
Jul 15, 2012 | 2000 Mercedes-Benz S-Class
Lcation of fuses
It's in the back of the truck, passenger side. Open the trunk, you'll see a cover. Open it, there's a fuse box.
Aug 17, 2008 | 2007 Mercedes-Benz ML350
Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome Exterior Accessory Abs Molding Trim Kit Set 2006 2007 2008 2009 2010 2011 Logo
4,306 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
