20 Most Recent
Mercedes Benz Travel Alarm Clock Questions & Answers
After replacing a dead battery
Kindly submit the question under Mercedes Benz ML320 section on the website by clicking this
link so that the top automobile experts can view and provide a solution to the problem.
Thanks for using FixYa.
97 s500 had for 6 mths- just a few days ago the
Since its a 97 Im pretty sure not the only owner. Some one possibly had an alarm uninstalled and didnt properly connect wires back, and now they came loose. Just check all connections on door panel to see if theres any signs of tampering
Lost ML320 Audio System Security Code
A trip to a Mercedes dealer with your log book and proof of i.d and provided the stereo is the origional factory fit then they should be able to track down the code and instal it for a minimal fee.I needed a new key for my c36 amg,gave them the info from the log book and an origional pre programed key arrived 4 days later from germany.
As i wash my car front windscreen,water runs into
The drains in the gutters under the hood are clogged. Straighten out a wire coat hanker and push it down to break up the clog. Road dirt, dust, traction material & leaves & pine needles will form a plug very fast.
ML500 2002 - Rear passenger door won't unlock
this is nothing to do with rear door not opening,the lock is stuck because no body has ever oiled the mechanism with a good old fashioned oil can,best thing ever invented the oil can,forget the silly fish oil sprays
P 2096 CODE MERCEDES ML 320
The causes for this DTC may include: Low fuel pressure caused by a clogged filter, failing fuel pump, failed fuel pressure regulator or clogged or leaking injectors. Rough running engine due to misfiring plugs. Many engines have misfire codes to indicate the cylinder effected, such as P0304 for number 4. A large vacuum leak would cause a massive amount of un-metered air to enter the intake manifold resulting in an overly lean mixture. A large air leak at or near the number one oxygen sensor would also cause a lean mixture. A plugged converter will cause of host of driveability problems as well as set this code. A severely plugged converter will result in the inability to increase rpm when under load. Look for a code such as P0420 -- catalytic converter efficiency below threshold if the converter indicating a faulty converter. A faulty oxygen sensor. This will set a code in itself, however, a faulty oxygen sensor does not automatically condemn the sensor. The code just means that the sensor signal was not within specifications. An air leak or any of the above will cause an erroneous signal. There is a multitude of O2 codes relating to O2 performance which gives a clue to the problematic area. The Mass Airflow sensor will also cause this problem. It would be accompanied by a code such as P0100 -- Mass Airflow circuit malfunction. The Mass Airflow sensor is a hot wire that senses the volume of air entering the intake manifold. The computer uses this information to control fuel mixture. Rusty exhaust systems, cracked exhaust manifolds or damaged or missing gaskets or donuts will cause air leaks. If you need further help, reach me via phone at
https://www.6ya.com/expert/david_1f7d1c330c9dd97d
UNLOCK CODE
Look in your glove box in the owners manual or with the papers you got when you got the car, and see if you have a card or a piece of paper that tells you what the code is. If not you will have to call your local mercedes dealer and give them your vin/serial number and they can look it up for you. If you need further help, reach me via phone at
Mercedes wiper washer problems
If the pump works but no water comes out, then the washer nozzles might be clogged. They're usually unblocked using a small safety pin. Also check the hose line from the pump to the washers as they might be perished. If there's no pump noise then it might be (a) pump fuse, (b) corroded contacts (c) blown pump.
