20 Most Recent Mercedes C-Class Exterior Pillar Posts Trim Set Questions & Answers
you can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly
, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
Mercedes C-Class... | Answered on Jan 28, 2019
Whatever you do dont push the pedal to th floor on fuel injected motors, you will do nothing but harm to your vehicle very dangerous as each time you mash pedal to floor gas will dump in the intake, and lay at the bottom and not burn time and time again till one time you blow out your intake, never push the pedal down and turn key on fuel injection, crbed motors are different than injected motors, hope this helps.
Mercedes C-Class... | Answered on Jun 04, 2016
Ensure the throttle body is clean a sticky throttle valve causes the ESP light to come on , and the vehicle to lose power this is an intermittent failure and is normally experienced just after a fast pull away
Mercedes C-Class... | Answered on Oct 09, 2015
sounds like you have trapped/chaffed wiring under seat or around seat recline hinge, remove seat and have a close look at the wiring. disconnect battery first because airbags in seat and seat belt pretensioners i think are fitted to this car. good look
Mercedes C-Class... | Answered on Sep 17, 2015
code p203 d refers to reductant level sensor ---circuit high
or
injector ,cylinder4--signal low===causes for sensor are --wiring --reductant level sensor---ECM
and for cylinder 4 wiring---shorted to ground--injector--ECM you may have to get what a reductant sensor does from a MB service centre and see if it controls the cam advance mechanism
Mercedes C-Class... | Answered on Jun 13, 2015
Hi,you need to take wheele off put the car up on axle stands then there is a tool called a spring compressor,(which are exspensive)or you can do what I did,
I undone the back nut to the lower wishbone put a jack under the wish bone remove the bolt to the wishbone and slowly lower the jack take spring out then replace with new and jack up replace bolt job done,hope this was some help.
Mercedes C-Class... | Answered on Apr 03, 2015
this wouldn't normally cause the light to come on try disconnecting it again leave an hour then try reconnecting earth first might solve the problem
Mercedes C-Class... | Answered on Apr 02, 2015
i have a problem with mine if its an old one the motor and mechanisem slows down and some times doesn't close all the way properly you could try cleaning the rubber seals around the out side it may just be sticking as it tries to close properly the rubbers go hard with age and could be making it stick
check the small housing that comes from washer bottle make sure that thats all attached if thats ok stick a pin in the jet as a build up of muck can get stuck in it blocking the jet up
Mercedes C-Class... | Answered on Jan 20, 2015
have you checked the oil level in the box if its low it will hesitate o go into gear
Mercedes C-Class... | Answered on Jan 07, 2015
Checking the fuel pressure is a job for the trained person with the right gear. You would need expert hands on help.
Mercedes C-Class... | Answered on Jul 30, 2014
It won't be fused separately, the gauge will be covered by the dash fuse. If the gas gauge is not moving then check the wiring by tracing the sender unit at the tank. It may be accessed through a small panel in the trunk floor. Pull off the sender wire, ground it on a clean metal surface and with the ignition ON, see if the gauge moves. If it does, then suspect the sender.
P2097 throttle valve block (ice up);
P2098 component N2/7 (SRS controller) crash signal error.;
Mercedes C-Class... | Answered on Jun 19, 2014
hi look at this hope this is ok for you
http://www.youtube.com/watch?v=dSxs47TeGo8
full removal video
Mercedes C-Class... | Answered on Feb 22, 2014
hi here is a video wouldent think you would have to remove bumper but you might http://www.youtube.com/watch?v=dSxs47TeGo8
sounds like a dodgey ignition switch or dodgey key fob as they need to read each other to work
if you have the key, yes, if you have just a key fob (keyless entry) then no because the locks still need power from the car to function. also a "slim-jim" would get it, might throw a security code though when batt is replaced, if you use a coat hanger be sure to place something behind it to not scratch the paint!
Mercedes C-Class... | Answered on Dec 01, 2013
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
29 questions posted
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Mercedes-Benz Vehicle Parts & Accessories
Most Popular Question
gas gauge fuse called benz c320
  • Vehicle Parts & Accessories
