I bought the dcr-dvd105 and lost the cd-rom that you suppose to download to your computer so it can read the mini dvds. do you know where i can simply purchase that cd-rom?
If your cam has a firewire connection, you could plug it into the macbook and use iMovie to transfer the videos over. You can also get an external DVD drive to put those tiny DVDs into to transfer it over.
Finalizing only allows your CD or DVD to be compatible with other units and to prevent any additional files from being added. If you initialized instead of finalizing you may have wiped out your files, but I doubt it.
Try this: Play your CDs on the original unit where they were recorded. If you see pictures, you should be able to transfer them. Try running a USB or firewire cable directly from your camera or DVD player into your computer and capturing that way.
You did not mention what kind of a computer or photo capture device you are using.
Hi!
Unfortunately, your camera does not have a USB jack, and does not have any way to transfer digital data from the disc to your Macbook.
I'd suggest loading your disc to a computer with a non-slot loading dvd drive, download your footage there, and either burning the data to a regular-sized dvd or putting the data in a flash drive to transfer it to you Macbook.
Hope this helps!
i dont think that you can keep the menus from each mini dvd. but you can create your own dvd video with menu and at the same time you can merge all of your mini dvds. After you upload the mini dvd videos to your computer then use Nero 8 or 9 Software. On Nero look for dvd editable and browse your dvd videos then do as the instructions says to you. you should burn that with one DVD disc with menus of your own choice
Dear Magician1506
You should copy all mini dvds/ files on to computer system HD and please use any good quality dvd burning software and make new menu.
I have a firewire from sony 105 to macbook pro--DOES NOT WORK--adapter i used from Sony mini 7" dvd player -- thought I had it fixed :( old camera out of time....
