Restoring your Joybook to factory default
settings:
This process will ERASE ALL data on your system drive C: and
restore the system to the default factory configuration.
If this option is selected, all programs you installed or data you
saved on the C: drive will be erased. However, data on the D:
drive will not be affected.
a. To restore your Joybook to its factory settings, click
Full System Restore - Factory default settings under
the Restore tab.
b. Follow the on-screen instructions to complete the task.
You have to enter its service mode to do a factory reset. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand devices are given. Never forget to exit the service mode, after all adjustments have been done.
go into the menu and reset the settings to factory default. after that, select computer again and see if it recognizes it. you may need to change the resolution to match the laptop.
For that you need to reset factory defaults settings for bios. For reset bios u have to open back side of your laptop then u find motherbord circuit there. pull cmos cell on motherbord for 15 minute then it reset to defaults. Also
u can reset with jumper settigns read carefully on mother bord there is
1 jumper near cmos cell u read there " bios reset or clear" It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset. then again set it in 1-2 its original position. Then it not want password.
