Question about BenQ Joybook A53 Notebook
My laptop is BenQ Joybook A53. After installing Windows 7, 1st day I faced sound problem in my laptop. But the next day, I found that there is no sound device in my laptop. I tried several times to install sound card with my orginal CD driver but all my attempts were failed. Pls give me advice to solve this.
Posted by Tazul Islam Bhuiyan on
virtual_a
  • 531 Answers
Hi Tazul
BENQ A53 AUDIO DEVICE/DRIVER INCOMPATIBILTY WITH WINDOWS 7
Please look at the following official BenQ Support and Driver Downloads website:
http://www.benq.com.au/page/?pageid=4&plid=18&pid=1359&s=1
As you can see clearly, the manufacturer of your laptop intended and designed it for use with only Windows XP and Windows Vista, not Windows 7.
Windows 7 can be misleading because it contains a huge built-in database of various device drivers, which can easily make it seem as if it is compatible with computers that it is not actually designed for. If all the other devices on your notebook seem fine apart from the Sound Device, it would appear as if this is what has happened to you. The Driver CD you tried is unlikely to be compatible with Windows 7.
Any website claiming to have downloads available of Windows 7 Audio Drivers for your notebook, are almost certainly of the type (Bait and Switch) that attract you only for you to discover that no such driver exists on their download database. They do this to win business from their competitors. Their aim is that you will buy something else from them instead.
I seriously doubt that any Windows 7 driver exists for the Audio Chip in your notebook.
You are really faced with two choices.
If you want to use the notebook's own Audio Chip, then you will almost certainly have to install Windows Vista or Windows XP and forget about Windows 7.
If you are determined to continue using Windows 7 and you are certain that all other devices and their respective drivers are installed and functioning correctly except the Audio Device, then you can buy a small, very expensive External Sound Device for Notebooks, Laptops and Netbooks that you must pre-confirm with the supplier, befor purchase, to be guaranteed to be Windows 7 compatible. See here for some examples:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=external+usb+laptop+soundcard&x=9&y=20
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Posted on Oct 09, 2011
IQUIT
  • 3,940 Answers
Generally, the Windows Vista Drivers will work for WIndows 7 so you can try the Vista driver here:
If no joy try this driver:
http://wikidrivers.com/wiki/Realtek_HDA
Posted on Oct 10, 2011
Cant open webcam benq a53
Open the device manager and check to see if the webcam is there. Does it have an exclamation mark or an 'X' over it? Uninstall it and reboot the computer. It should be re-installed when windows finishes loading. You can download DriverBooster, from IOBit and run it. it will detect your drivers. If the webcam is bad, this will not help.
Oct 31, 2013 | BenQ Joybook A53 (9H.Y26AB.V09) PC...
Benq joybook A53 sound problem
you can buy the USB Card sound and working by it ..
Nov 04, 2011 | BenQ Joybook A53 Notebook
My Wifi is not working. My laptop sound is scratchy. I want to upgrade my processor from celeron to core 2 duo which one i should select for cpu upgrade?
Two main things to know before you can attempt a Processor upgrade.
1) What Processor socket is on the motherboard?
2) What motherboard chipset is on the motherboard?
(Northbridge and Southbridge chip. Unless it's a motherboard that supports Intel Core 13, Core i5, Core i7, and Core i9 processors)
According to specifications I found online just now, the BenQ Joybook A53 comes with an,
Intel Core2 Duo T7250 processor,
http://laptops.techfresh.net/benq-joybook-a53/
Scroll down.
(Only 512MB's of DDR2 Sdram (SO-DIMM) ram memory that operates at 667Megahertz?
{ PC2-5300} Yecch! You need at LEAST 1GB of ram memory. (512MB + 512MB = 1GB.
2GB would be best)
http://www.laptop-software.com/benq/benq-joybook-a53-features-and-specifications/
Information on the Intel mobile Core2 Duo T7250 processor,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Core_2_Duo_2
Scroll the page down until in the left column you see T7250. Then read across, and match the headings above.
Uses a Socket M processor socket,
http://en.wikipedia.org/wiki/Socket_M
Is your problem directed to a BenQ Joybook A53 Notebook PC, or is it another model?
Sep 16, 2011 | BenQ Joybook A53 Notebook
I need vga drive benq joybook A53
Take a look on this page.
http://notebook.driversdown.com/notebook-drivers/BenQ-Joybook-Display-Driver_125511.shtml
Or have a web search for:
BenQ Joybook A53 Chipset & Display Driver V6.24.10.3820 for Windows XP
Aug 23, 2010 | BenQ Joybook A53 Notebook
I don't have any sound device on my laptop?how can fix it?
Download the driver from here DriverDownload and follow the instructions. Otherwise you'd miss some steps which will make you get confused. Good luck. Thanks for using FixYa
May 29, 2010 | BenQ Joybook A53 Notebook
I hv installed windows vista in my Benq a53 joybook drivers r nt loading? plz give me the link from where i can download
There r few links just copy paste it in your INTERNET BROWSER and fill in necessary details page if come up then download and install drivers
http://www.pricecomparehelp.com/page/29310.html
GOOGLE LINK FOR BENQ DRIVER SEARCH
http://www.google.co.in/search?hl=en&q=Benq+a53+joybook+drivers+download&btnG=Google+Search&meta=&aq=f&oq=
Mar 05, 2009 | Microsoft Windows Vista Ultimate Edition
BenQ Joybook A53 Notebook Logo
Top BenQ Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Paul Bade
Marvin
Marvin
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
