Timer is wired incorrectly.
1) If you have battery-operated Intermatic EJ500 or ST01C, with red, blue, black and green wires:
Then red wire is where blue wire should go. Swap blue and red wire.
2) If you have Aube battery-operated timer, add a comment and say if you are replacing single-pole or 3-way switch. And say where each wire is so far.
3) If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Heres
how to wire timer
1) Timer-green-wire connects to bare ground
wire.
2) Switch has 2 wires. Take switch wires and connect them to
timer-black-wire and
timer-red-wire. Choose either one for now.
3)
In back of electric box are white wires twisted together and covered
with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then
connect timer-white to bare ground, along with timer-green wire.
5)
Turn on electricity, and push ON-OFF button. If lights come on, timer
is wired correctly. If lights do not come on, then reverse timer-red
and timer-black wires.
