20 Most Recent UPM Programmable Wall Switch Timer Questions & Answers
The attached page is long but will show you how to reset and program your wall switch timer
UPM Programmable... | Answered on Nov 24, 2015
Copy following link to identify timer and download manual:
http://waterheatertimer.org/UPM-timers-and-manuals.html#ETW
ETW can be used to replace 3-way switch.
3-way switching has 2 switches. Timer can replace one switch or the other switch, but not both.
The remaining 3-way switch must be rewired as shown in manual. What the remaining 3-way switch does is reverse timer programming, so programmed ON times become OFF times, and OFF times become ON times.
Add a comment as needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
UPM Programmable... | Answered on Jul 19, 2013
Is this a question?
UPM Programmable... | Answered on May 12, 2013
Pull thermostat from wall, change batteries located on back of device.
Model number will probably appear on back.
Goole-search model number .pdf
Add .pdf to search parameter to help locate instruction manual.
Or add re-post question on fixya and include model number for possible assistance locating product manual.
UPM Programmable... | Answered on Feb 24, 2013
1) Copy following link to identify timer and download possible manual:
2) Unsure which timer you have.
Digital wall timers usually have back-up that holds memory for certain length of time before current time disappears.
Usually the programs remain indefinitely until timer is manually reset.
3) Why do you want to turn timer off?
Usually in-wall timers consume 3 watts of power per year.
Contrast big screen TV consumes 3 watts per hour standby loss when TV is turned OFF.
UPM Programmable... | Answered on Feb 13, 2013
Posted under UPM wall timer.
Timer model and brand and approx age are unknown.
Is this new installation?
Was display brighter before?
Most timers have 1 year limited warranty.
Buy another timer.
Add a comment.
UPM Programmable... | Answered on Sep 22, 2012
If this is new installation, the wiring is incorrect.
If this is old installation, try resetting timer.
Copy following link to see how to wire single-pole timer.
http://waterheatertimer.org/How-to-wire-timers.html
UPM Programmable... | Answered on Aug 04, 2012
It sounds like wiring is wrong.
If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
Add a comment any time.
See instructions along with image at following link:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Heres how to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button > with GE timer, door is push-button switch. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
UPM Programmable... | Answered on May 22, 2012
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
UPM Programmable... | Answered on May 07, 2012
1) Open following links to identify same-similar timer, and download possible manual:
http://waterheatertimer.org/images/ETW350-buttons-200.jpg
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/images/Woods-49556-400.jpg
2) If timer does not appear on links above, take in-focus photo and post on flickr, and then add a comment with link to photo so I can see the timer for possible identification.
UPM Programmable... | Answered on Aug 09, 2011
You posted under UPM programmable timers
Open following link to identify product and download manual
Q1) Some UPM timers, and other brands, offer countdown feature in addition to regular programming.
So you choose between regular programming and countdown.
Countdown is for a bathroom fan for example.
Push the button and fan turns on for set amount of time.
After countdown is over, fan turns off automatically.
Q2) Yes all days of the week can be selected.
Set event 1 ON for all days.
Set event 1 OFF for all days.
Do not set more events unless you want more on-off events.
Q3) Switch position depends on model number.
Add a comment with model number to identify product and I will look at manual alongside you.
Or try the switch in different positions.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
UPM Programmable... | Answered on Apr 29, 2011
Please add a comment with band and model of timer so I can advise others about this difficulty.
UPM Programmable... | Answered on Feb 24, 2011
You posted under UPM 350 programmable timer
Manuals for all UPM timers are missing key explanations, despite the lengthy manual.
I think there are 3 things to look for:
1) Program1 is ON and program2 is OFF and program3 is ON etc.
2) When setting days, be sure that ON and OFF are set for same days so there are no conflicting programs.
3) Timer gives three modes: Countdown and Random and Programming. Countdown is for a bath fan when you want to turn on fan with push of button and have timer turn off fan automatically after the countdown expires. Do not use countdown or random functions when you want timer to perform ordinary on-off functions.
You posted under UPM programmable wall timers.
These timers are not set for humidity.
Add a comment with exact product you are working with.
UPM Programmable... | Answered on Feb 15, 2011
UPM Programmable Wall Switch Timer Logo
Popular Tags
39 questions posted
Top UPM Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an UPM Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • UPM Hardware & Accessories
Most Popular Question
purpose
  • Hardware & Accessories
