The house is 13 years old and the ceiling is yellowing. The ceiling is a white california knockdown.
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches. It sounds like the Electrician set up the junction box for two circuits(Lights and Fans). i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
SOURCE: installation of wall remote for harbor breeze ceiling fans
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
SOURCE: Fan with remote won't work with wall switch. I
kjob, if you haven't figured you fan problem out yet, the must be set to the highest setting through the pull chain for it work correctly with the remote.
SOURCE: Purchased: Carriage House II
check this link for a diagram, http://www.wiringhelp.com/electrical/electrical-how-to/how-to-wire-a-ceiling-fan.html go down to the diagram with 2 switches,, click it, it will enlarge,
