Question about Dryers
Installation of wall remote for harbor breeze ceiling fans
The wall remote switch plate has a green ground and two black, NO white cords how do I wire it to wall were old regular switch plate came out of
Posted by Suzie Boyette Wunder on
  • Anonymous Mar 16, 2014
    need directions for remote
Anonymous
One black wire on the switch hooked to the black sources wire. The other black wire on the switch hooked black up to the fan. The green on the switch wire goes to the bare wire. If there is bare wire you can use the white wire.
Posted on Nov 25, 2008
Anonymous
The white wire is a neutral conductor. The black wires connect 1 to line (hot) from the panel, and the other goes to the wire that used to go to the ceiling fan.
NEVER connect the white wire which carries return (used ) current back to the source, to the bare or green wire.
Posted on May 05, 2010
Anonymous
  • 4 Answers
Harbor breeze ceiling fans are excellent quality at a reasonable price! But keep in mind there are pretty much troubles on these affordable ceiling fans.
http://www.ceiling-fan-wizard.com/harbor-breeze-ceiling-fans.html
Posted on Nov 21, 2008
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
Wiring instructions for harbor breeze ceiling fan model wsc52wb5c
Since that is a low-end store brand(Lowes) I can only guess the usual. Black to black,white to white,green to green or copper wire,blue to red.If no red wire in ceiling then put blue & black from fan to black in ceiling.
Mar 27, 2013 | Dryers
Iam wiring a celing fan with a remote(added). The wires from wall switch are green(ground), white(neutral) black(fan) red(light)? Hooked to the wall switch remote. 2. Fan green, white, blue, black. 3....
I'm an electrician and will be happy to help you out. I need a little more information to answer accurately first. 1) What is the brand and model number of the "ceiling fan with remote". 2) If replacing / adding switches, how many locations will control the fan / light fixture? Please provide this info and I'm sure we can get this working very quickly.
Dec 12, 2012 | Dryers
I removed a Hunter ceiling fan with a light that was installed about 30-40 years ago. There are 2 white wires and one black wire coming out of the ceiling. There is one single switch on one side of the...
The black wire is most likely your neutral. The wall plate should have one light switch and a fan control. If you connect an incandescent or halogen bulb to one of the white wires and the black and you flick the light switch or turn on the fan switch the light should light, you can then determine which white wire is doing what.
cheers
Mar 30, 2017 | Dryers
Hampton Bay 5745a ceiling fan, no blue wire.
The blue wire is running into the built in receiver inside the fan housing. You will not be able to install another receiver to the fan and have control of the lights. You will be able to control the fan though.
Aug 02, 2012 | Dryers
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
May 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Dryers Logo
3,620 people viewed this question
Top Dryers Experts
Marvin
Marvin
Mike
