All my power windows stopped working at once along with the switches, i checked the fuse but the fuse is still good.
SOURCE: 1999 Pontiac Montana passenger sliding door stopped working.
Verify the wiring harness which passes under plastic step & carpet at front passenger side. This wiring harness goes from the firewall to the pillar on the right side and some have crimped connectors in them to act as junction between two or more wires (ususlly the 12volt feed), which deteriorate with time, especially with Salt & Water. Then the electric sliding door stops working and even driver the electric seat can loose power.
SOURCE: need help with 2000 grand prix stop lights
Look for a broken ground wire at the back of the car!
You ran the power all the way down to the bulb which means there is only one thing left. The ground lead!
You can try grounding the brake light socket with a test light or a lead from your multitester to check it.
SOURCE: ac controls along with power windows stopped
check the fuseable links from the starter and also the battery area in the main wiring harness you have one blown out
