Frig not kicking on after the defrost mode. Replaced the defrost timer, I think it did help some. Now it works for maybe 1/2or3 days, then won't kick on again. When I open the freezer door & or tap the temperture control thermostat it starts right up. Again it may last 1/2/ or 3 days and then do the same thing. Wanted some confirmation (reasurance) that there is a good chance that the Temp Control Therm is what I need before spending another 60.00 bucks. Thank you for any help.
SOURCE: Lights are on but nothing else
Checked the switch in the freezer and it was bad. Odd time for it to go out, but it was not working and it would work intermittently if you shook it.
SOURCE: Troubleshooting defrost system failure on Amana Fridge
YES YOU GOT IT,IT'S THE BOARD BECAUSE EVERYTHING ELSE CHECKED OUT GOOD,BOTH FANS,HEATING ELEMENT,DEFROST THERMOSTAT,THE ONLY OTHER THING I WOULD DO IS TURN THE THERMOSTAT OFF IN THE FRIG.TO SEE IF THE COMPRESSOR AND FANS TURN OFF,WAIT 3 MINUTES AND TURN IT BACK ON, IF THAT CHECKS OUT THEN IT HAS TO BE THE DEFROST TIMER,LET ME KNOW-MIKE
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
SOURCE: Frost free freezer icing up
It should still be covered under the warranty.
How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
SOURCE: automatic defrost not working, but manual is?
Yes if the heater and defrost thermostat are good then the problem is the control board.
Don't know who wrote me back, but I thank them.
