The unit still runs through the drying cycle but never gets hot enough to dry anything. usually, it gets so hot that the door won't unlock until several minutes after it is shut down -- even with no power. but now I can open the door right up since it's not hot (the indicator says hot and door locked but neither is true). i am trying to get an idea what the problem is before I pay someone to come tell me that I can't afford to fix it.
SOURCE: hwd1000 drying
More than likely your heating element is dead.You can get one at a hardware store.There not that dificult to replace.I could walk threw it with you on live chat.
Hope this helped. Let me know.Please rate.
For more help go to live chat.
lenwest
SOURCE: My HWD1000 Haier Washer/Dryer combo error EC4
EC4 is regarding: The temperature of air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
The dryer heater is not working properly. Call a repair technician.
Alternatively, create a custom wash cycle with no dry cycle and hang dry the laundry if you are past warranty and do not want to pay to repair it.
SOURCE: Dryer Problem
EC4 The temperature of air vent
You need to call for repairs. Probably the heating element is faulty.
You can create a custom program without a dry cycle and hang dry your clothing.
SOURCE: Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
